Computer gurus
  • ekim
    • Jun 2013
    • 106
    I thought you tried a different adapter in post#7 ?
    1980 XS1100 Standard (G)
    Original Owner
    Stock plus:
    2011 FJR1300
    1978 SR500
      Not sure I installed it correctly according to my computer guy, didn't disable the internal one.
      • ViperRon
        • Feb 2011
        • 1062
        • Woodstock, VA
        Greg not to say this is your problem but when updates go out from a manufacturer like Qualcomm sometimes they cross platforms so it would not be uncommon for the manufacturer to tweak the driver for their devices and it would be possibly the same tweaks on Windows 10 and 7 and 8 and 8.1. So therefore you are working fine one day and the next intermittent like my cousin was and then you do not work at all. Something happened and its unlikely the card broke but highly likely an update on any of the more modern platforms creating the issue. This is the point I was trying to get across the recent update on my cousins computer only made her computer Wi-Fi card fail her Ethernet connection still worked fine and 3 other computers worked fine on the Wi-Fi and switching to another router fixed everything for her.
        Rodan
        1980 G Silverbird
        1198 Overbore kit
        Grizzly 660 ACCT
        Barnett Clutch Springs
        R1 Clutch Fiber Plates
        122.5 Main Jets
        ACCT Mod
        Mac 4-2 Flare Tips
        Antivibe Bar ends
        Rear trunk add-on
          Not my call to buy a NEW router just because my laptop doesn't work right. Stands to reason that since all other devices work fine there's an issue with mine. I just need to find out what it is...............and fix it.
          Starting at the wifi adapter.
          • ViperRon
            • Feb 2011
            • 1062
            • Woodstock, VA
            #35
            Most Routers have an update flash utility that actually does an update of the firmware and program codes for the router. It may be that updating the router will help but I am not sure. This update on all routers I have used does not change configuration and has always worked quickly and smoothly for me.
            Ron
            Rodan
            1980 G Silverbird
            1198 Overbore kit
            Grizzly 660 ACCT
            122.5 Main Jets
            ACCT Mod
            Mac 4-2 Flare Tips
            Antivibe Bar ends
            Rear trunk add-on
            • Bigfoot
              XS-XJ GURU
              • Sep 2005
              • 1422
              • Kansas City, Missouri
              #36
              Greg, did you try the wifi adapter again.... with your internal one turned off?
              Harry
              '79 Standard
              '82 XJ1100
              '84 FJ1100
              Acta Non Verba
                Vlad is putting a new adapter in it as we speak. He said he's seen this before. With Asus units.
                • Bigfoot
                  XS-XJ GURU
                  • Sep 2005
                  • 1422
                  #38
                  Sorta what i told you all along. :P
                  Harry
                  '79 Standard
                  '82 XJ1100
                  '84 FJ1100
                  Acta Non Verba
                    OK Harry, swapped out the Atheros adapter and put an Intel in there and it STILL does the same thing.
                    • Bigfoot
                      XS-XJ GURU
                      • Sep 2005
                      • 1422
                      #40
                      hmmm, have you tried hitting it?
                      Ya know, like Fonzy.
                      IDK man, hard helping on something like this when i'm not there.
                      Harry
                      '79 Standard
                      '82 XJ1100
                      '84 FJ1100
                      Acta Non Verba
