Yyooooooo...(2017 yamaha scr 950)....
  • ERM83
    • Apr 2016
    • 314
    • Lehigh Valley, PA
    The V-twin-based SCR950 scrambler motorcycle joins Yamaha’s Sport Heritage line. Check out the First Look review at CycleWorld.com.
    I'm WAY into this!! I know it should've gone in "other bike discussion", but most of the traffic is here, and I wanted to hear everyone's thoughts!
    80' XS1100 SG "Dottie"
    79' SF carbs
    MAC 4-1
    K&N Pods
    Accel 3.0 coils
    Tarozzi fork brace
    TC fusebox
    Picture update soon
    http://i53.photobucket.com/albums/g4...psej6wqu9l.jpg
    79' XS1100 SF (parts, will be reborn)
    http://i53.photobucket.com/albums/g4...snfgpozqn.jpeg
    • 3348
    Oh baby, I LIKE the concept, but the engine... If the engine tune is anything like the Bolt engine, it'll be making just under 50 hp and 57 ft/lbs at the rear wheel with a 6,700 rpm redline. From 942cc, that isn't terribly much. I had a VStrom 1000 (996 cc, 9,500 rpm redline) that dyno'd at the rear wheel 86hp and 62 ft/lbs, had tons of grunt down low but a decent top end. Also a smooooooth 90 deg V configuration with 98mm bore x 66mm stroke which allowed higher rpm with the shorter stroke.
    For a "Scrambler" bike, I would think the tune would yield more hp up top, but not sure how you deal with the rpm handicap (6,700 redline) as the bike is a relatively square bore/stroke at 85mm x 83mm. That is similar in ratio to the XS1100 at 73mm x 68mm, so maybe they can get a bit more up top without losing a whole lot of bottom end. The Bolt is good for just over 100 mph, which is more than needed in the technical sense but not a lot of excitement considering my 1982 Honda CX500 (496cc) will do that.
    XSR900 is looking good as well...
    2001 ZRX 1200
    1982 Seca 750
    1983 Nighthawk 550
    • MarkD
      • Jun 2013
      • 488
      • N. Michigan
      ERM-- That is a cool bike, probably able to do a lot of things pretty well. Would love to take one on a little trip, and do some off roading. A little surprised by the weight, though, seems a little heavy.
      79 F
      1967 Suzuki X6 Hustler
      1973 Suzuki TM 125
      1979 XS1100 F
      2005 Kaw. Vulcan VN800
      1991 BMW K75
