Weird stuff
Hmmm, gas tank cap vent...where have I heard that idea before....oh yeah....in my FIRST reply a few days ago....guess that speed reading doesn't always pay off eh Greg!Hey Greg,
Well, the most common problems have already been eliminated by no octy and the gravity feed petcocks. That leaves a possible air lock in the in line filters, OR...when was the last time you checked the gas cap vent??? It might have gotten gummed up and you developed the dreaded vac. lock in the tank once it got just so low! JAT!?
T.C.T. C. Gresham
You got me there TC.
I did miss that but I did check it and it's still shiny new and clean.
Where did you source the cap? How long was it sitting on the shelf before you bought it? The filter in the cap is a piece of sponge in the OEM version and it rots over time. I expect the aftermarket version won't last half as long. I replaced mine with a tiny piece of Scotch-Brite. I don't know how good a filter it is, or how long it will last, but I have three Yamaha Special caps running that way and have been for some time.Marty (in Mississippi)
XS650EComment
I know what the inside of the cap looks like Marty, I've had a couple 3 apart.
I don't really remember where I got this cap from since it's been 6 - 7 years since I put it on there. I'm thinking parts-n-more.
It's EXACTLY like an OEM cap, I just swapped the lock out when I got it so my key fit.Greg
Well you unfortunately have one direction to go Greg. As you said it was all cylinders and you have eliminated the gas flow issues so the only other direction is electrical and I know you have checked that but a bad crimped wire going to supply the ignition fuse give me a fit 3 years ago because of how it acted. I only had the bike cut off twice but it developed start problems related to the self hold path that drove me nuts and I just had to jumper around to find it because a meter would not find it. Good luck hope your issue does not act like mine did in the end.To fix the problem one should not make more assumptions than the minimum needed.
Rodan
1980 G Silverbird
1198 Overbore kit
Grizzly 660 ACCT
Barnett Clutch Springs
R1 Clutch Fiber Plates
122.5 Main Jets
ACCT Mod
Mac 4-2 Flare Tips
Antivibe Bar ends
Rear trunk add-on
http://s1184.photobucket.com/albums/z329/viperron1/Comment
Old school theory works here majority of time a I and Ron have stated......."electrical before fueling"Well you unfortunately have one direction to go Greg. As you said it was all cylinders and you have eliminated the gas flow issues so the only other direction is electrical and I know you have checked that but a bad crimped wire going to supply the ignition fuse give me a fit 3 years ago because of how it acted. I only had the bike cut off twice but it developed start problems related to the self hold path that drove me nuts and I just had to jumper around to find it because a meter would not find it. Good luck hope your issue does not act like mine did in the end.
. In this case from what you initially stated........secondary ignition, not primary.
Last edited by motoman; 04-25-2016, 03:01 PM.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Switching from main to reserve fuel must have completed the broken circuit..
Well Brant, I checked and rechecked every electrical circuit on the bike when my exhaust was having an electrical issue. Pretty sure it hasn't changed in 3 months since all the electrics are working fine.Greg
Well, even tho you replaced all that under timing vcover at some point, those wires flexing and breaking internally sure can cause sporatic ignition issues.......all works and checks out fine, then for an unknown reason doesn't while running. That advance mechanism sure can raise TEMPORARY havoc with that constant wire movement when bike is running
. IMO, still would be worth removing that cover and trying to separate every inch of those wires,...... just for peace of mind if nothing else.
Last edited by motoman; 04-26-2016, 02:13 PM.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
