Always been good at breathing life back into lawn equipment, till now. Neighbors one year old Homelite weedeater wont start. He put on new carb, sparkplug, fuel filter and fuel. No start. Give it to me I say, I will make it live. Yea, right. Check spark, good, check compression, good (120 psi, no leak down). Fresh fuel mix. Fuel filter clear and no cracks in fuel lines. Pull exhaust off thinking it was plugged, no joy. Replace plug with "known good unit", no joy. Primer bulb working. This thing wont even pop with starting fluid or "direct injection" with fuel. Check piston thru exhaust port and intake, clean, no sign of running straight gas. I admit defeat and am ready to return said weedeater with my head hung low and man card in flames. Fuel, compression, spark. What more does it want from me? Suspicion but haven't gone that deep is flywheel has sheared and "timing" is off. On top of this, my freaking truck wont start
Turn in my mancard?
Originally posted by webbcraft2150 View PostAlways been good at breathing life back into lawn equipment, till now. Neighbors one year old Homelite weedeater wont start. He put on new carb, sparkplug, fuel filter and fuel. No start. Give it to me I say, I will make it live. Yea, right. Check spark, good, check compression, good (120 psi, no leak down). Fresh fuel mix. Fuel filter clear and no cracks in fuel lines. Pull exhaust off thinking it was plugged, no joy. Replace plug with "known good unit", no joy. Primer bulb working. This thing wont even pop with starting fluid or "direct injection" with fuel. Check piston thru exhaust port and intake, clean, no sign of running straight gas. I admit defeat and am ready to return said weedeater with my head hung low and man card in flames. Fuel, compression, spark. What more does it want from me? Suspicion but haven't gone that deep is flywheel has sheared and "timing" is off. On top of this, my freaking truck wont start81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
Spark test good on weedeater. Good enough to ignite spilled gas on workbench. Onery, cold blooded Dodge fired up, time for a new ballast resistor or hei conversion. Sometimes, only sometimes, those shiny new trucks look pretty good as do those shiny new bikes. But the current payments (like none) look pretty good on my ancient '75 Dodge W200 or 80g. The weedeater is about to have a Viking funeral.When a 10 isn't enough, get a 11. 80g Hardbagger
Sounds flooded out,pull plug,let sit over nite.Try to start next day full throttle and no choke.'80 XS1100 SG
Video of the Viking Funeral Please
I was thinking the flywheel may have a sheared key also, but those diaphragms in the carbs are touchy. One little speck of dirt and they won't run.
Got a leaf blower on the blink that I completely rebuilt that I may set in the Funeral Pyre also1980 XS1100G "Dolly G" Full Dresser (with a coat of many colors )
Originally posted by webbcraft2150 View PostSpark test good on weedeater. Good enough to ignite spilled gas on workbench. Onery, cold blooded Dodge fired up, time for a new ballast resistor or hei conversion. Sometimes, only sometimes, those shiny new trucks look pretty good as do those shiny new bikes. But the current payments (like none) look pretty good on my ancient '75 Dodge W200 or 80g. The weedeater is about to have a Viking funeral.Last edited by motoman; 04-10-2016, 03:02 PM.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
I vote with Schming. VIDEO.
get the owner to light the fire though
Phil1981 XS1100 H Venturer ( Addie)
Originally posted by motoman View PostActually, on your Dodge trk., the voltage regulator which is mounted on the firewall is a good placw to start. Those yr. Dodges were notorious for voltage regulator intermitant failures. I just suggest that since CDOT here having contracted with Chrysler for all there autos and trks. at that time had many a voltage regulator failure and a 'no start' scenario when the vehichles reached near the 100,000 mile mark, or adding an underhood steam cleaning. That's just 30yr. employed shop experience with CDOT speaking.When a 10 isn't enough, get a 11. 80g Hardbagger
How do you lose a mancard when your wife keeps it under lock and key?Try your hardest to be the kind of person your dog thinks you are.
I'm sorry, but
hahahahaaaa
81 SH Something Special
79 SF MEAUQABEAUXS
81SH Nor'eas tah (Old Red)
80 LG Black Magic
78 E Standard Practice
James 3:17
“Alis Volat Propriis”
Yamaha XS 1100 Classic
For those on FB
Originally posted by webbcraft2150 View PostJust wait, I'll get the sucker running.81 SH Something Special
79 SF MEAUQABEAUXS
80 LG Black Magic
James 3:17
For those on FB
