Paint - enamel or laquer?
    • 2054
    Not to advocate lacquer, but I can report neither of my lacquer projects had any compatibility issues over the factory paint.
    • dbeardslee
      • Nov 2007
      • 4385
      • Maineville, OH
      I'm not doubting anybody, but I have a hard time believing anything would react with 35 year old paint. The solvents have long since dried out of it. New paint is a different story.
      • XJOK2PLAY
        • 2099
        • Skiatook, Ok.
        I'd talk to the counter guys where you buy your supplies.
        If it's sealed correctly, should be ok. Without sealing, the paint will work it's way back to the metal.
        If it has enamel, and you don't seal it, and apply lacquer, you won't believe what might happen. Those two types of paints refuse to coexist, regardless of age.
        2011 Kaw Concours 14 ABS
        • dbeardslee
          • Nov 2007
          • 4385
          • Maineville, OH
          The tank I'm getting ready to go to work on has already been repainted. No telling what they used. I don't have it in my hot little hands yet since it's in transit after an ebay purchase. I've got another one out in the mancave, but I have to do some work on the metal where the trim ring bolts on before I can paint that one. And that one looks like it's been painted several times. And then there's the one that's on Betsy, but the inside of that one is pretty bad, and it's been lined. It would be the easiest of the three since it's already in primer, but I don't want to spend the time on it since the inside is questionable. But none of them have the factory paint on them.
            Originally posted by mrhammer2u
            To be more clear...my local auto body supply uses the same commercial grade paint in their rattle cans. They whip them up upon request. Goes on same as a sprayer (so long as you don't get any splatter when the nozzle clogs...HATE that!). Not sure all places do this.
            Same here, as majority of automotive paint ses/suppliers do. Peturers color when I did sidecovers some 9yrs. and perfectly matched original color.......no runs, drips or errors. Defy anyone to find they've been repainted.
