Kuryakyn Iso-Grips 6341 vs. 6241
    • 3971
    Anyone know the difference?
    • 3971
    Cassie
    Hello, this is Cassie. How may I help you?
    Mac
    Kuryakyn Iso-Grips 6341 vs. 6241. What is the difference? Please & thank you.
    Cassie
    6241 is chrome 6341 is black
    Mac
    Looking for a good black Iso Grip for 7/8" bars. Are the black one's all the same diameter?
    Cassie
    6340 is black 1''
    Cassie
    6341 is black 7/8''
    Mac
    The difference between the 6341 and 6344?
    Cassie
    If you look at the fitments you will see 6344 is for sport bikes
    Cassie
    6341 is for Honda, Cam-Am, Yamaha
    Mac
    I meant grip diameter. And, how would it matter if it was sport or street? 7/8" bar is 7/8", whether street or sport. Right?
    Cassie
    Some of the grips are bike spacific, if you need a universal grip you need to get a universal grip, the grips called out for sport bikes are only meant to fit sport bikes due to their throttle sleeves.
    Cassie
    So you need to go off of the fitments for the grips
    Mac
    Gotcha. Okay, thank you very much for you help!
    • jwhughes3
      • 2798
      • Home of the Alamo
      Ive used these. Great grips.
      John
      '81 XS1100H - "Enterprise"
        I use them too. They are amazing grips!
        • mrhammer2u
          • Aug 2014
          • 472
          • Northern, NJ
          The ad states "dampens handlebar vibration". Can any of you vouch for this? I'm still trying to find a reasonable way to get rid of the vibe on the throttle side.
          Rob - 79 SF
            Nothing is 100% but they do a pretty good job.
            • mrhammer2u
              • Aug 2014
              • 472
              • Northern, NJ
              Do you guys use the glue? What if you need to remove the grips?
              I've always used cheap rubber grips installed with hairspray. Sometimes they slide off with some persuasion, other times I did not mind cutting them off (cheap). These grips don't look like you can do either.
              Rob - 79 SF
                I did not use the glue. I should do something g with the left side though, I can move it some.
                • jwhughes3
                  • 2798
                  • Home of the Alamo
                  I used rubber cement. Not sure if it came with grips or bought separately.
                  John
                  • Bigfoot
                    XS-XJ GURU
                    • Sep 2005
                    • 1422
                    • Kansas City, Missouri
                    I love these grips, they are very comfortable and help with the vibrations. I got the "throttle boss" attachment as well, that is well worth the extra $20 bucks on a long trip.
                    We know you want to customize your bike and kick it up a notch, and with our Kuryakyn motorcycle parts, you can do just that! Explore our collection today.
                    looks like they sell bar end weights that will screw into these as well, but i have not tried them.
                    Oh, and i just used hairspray and slid them one. had hopes that if I ever need to remove them I could get them of without damaging them. As far as i know they DO NOT sell replacement rubber parts for these. You have to buy a complete set of grips if you tear that rubber up.
                    Harry
                    '79 Standard
                    '82 XJ1100
                    '84 FJ1100
                    Acta Non Verba
                      • 3193
                      Ian, you need the universal fit for 7/8 inch bars. Even then you will need to modify things a wee bit to make it all work.
                      You will need to sand or file off the factory ridges under the hand grip on the XS11 throttle to make it smooth enough to mount the new grips.
                      For the left side you will need a couple of wraps of electrical tape, just to close the gap and then you can install the new grips.
                      The glue they supply is both unforgiving and fast! So when you are using it, do not stop moving it until it is in the position you want or it will stay where ever you stop. Cost me a set of grips to discover that. I have not tried the other alternatives like hairspray so do not know what that may do.
                      Another thing is the grips are longer inside than our stock ones.... forget how much... but is room enough to put about 5 washers in the end of the grip which adds bar end weight. That is a good thing for sure.
                      All of my riders have them on the bars and I love every ride I take with them. Do they solve every issue...nope. But are they worth it in comfort... Heck Yeah.
                      • Bigfoot
                        XS-XJ GURU
                        • Sep 2005
                        • 1422
                        I didn't have a problem with those ridges, it went right on with the little bit of lube the hairspray gives you. The left one will move just a bit if i twist it hard but it isn't loose enough to worry about. i figure at least it will come off if I need it to without destroying it.
                        Harry
                        '79 Standard
                        '82 XJ1100
                        '84 FJ1100
                        Acta Non Verba
                          • 3193
                          Man you could not hammer mine on with a sledgehammer, without the ridge removal. Might be Canadian VS US bikes too.
                            I also did not have to do anything about the ridges. Mine went right one without any mods.
