Well, if the Kat shows up, the party will be ON, mofos! I had decided not to do it anymore, but I'm flexible.
Tech session west...
Sounds good , Hey Tony did you ever get that mod done for the R1 calipers ?1980 special (Phyllis)
1196 10.5 to 1 kit,megacycle cams,shaved head,dynojet carb kit,ported intake and exhaust,mac 4 into 1 exhaust,drilled rotors,ss brake lines,pods,mikes xs green coils,iridium plugs,led lights,throttle lock,progressive shocks,oil cooler,ajustable cam gears,HD valve springs,Vmax tensioner modComment
The R1 caliper mod came out rather well until I found out how much product liability insurance I would need to be able to sell them. There's a good reason why this kind of stuff is mostly made overseas. There's no way to sue them if there's a problem...
TonyHi my name is Tony and I'm a bikeoholic.
The old gray biker ain't what he used to be.Comment
Great idea, Tony! The plans for the new garage look awesome. I'll be there on Friday and Sunday afternoon. Saturdays in September are still work days...but the guys might like to sample Highway 22, Little Nestucka, Tillamook Farmers Market, then a round up Miami-Foley and 53 to 26, back out to 101, over Cape Lookout and Cape Kiwanda then back to Willie on Saturday. It'd be a little over 200 awe-inspiring miles.
A thundering herd of XS11 muscle would be a sobering sight to the wannabe tribe that inhabits local roads on weekends.1980 XS 11 Special: The King of Kong, 9th wonder of the world. Pacifico fairing, chopped shield, Yamaha hard bags, Diamond seat, T-Kat fork brace, XJ top end, YICS Eliminator, '80 carbs from Spyder Cycle Works, K&N Air filter, Fuse block, stainless steel valves & reg/rect from Oregon MC Parts. Raptor CCT, XJ air shocks, 850 FD, Sportster mufflers, Standard handle bar, Tusk Bar Risers, SS braided brake lines. Cat Eye speedometer. HID projector beam headlight, LED running lights.Comment
It might just be the 2 of us... I'll have the lift set up outside so we can put your bike up on it if you want to do anything to it.
Two irregularities are showing up now and then. 1) the headlight relay is slow kicking in, and 2) a couple of cylenders drop out. I let it idle for a second, rev it a couple times, and we're good again. Happens in the dry as well as wet conditions. I replaced plug wires about 10 years ago. May be time for some different coils, or there's a wire problem.1980 XS 11 Special: The King of Kong, 9th wonder of the world. Pacifico fairing, chopped shield, Yamaha hard bags, Diamond seat, T-Kat fork brace, XJ top end, YICS Eliminator, '80 carbs from Spyder Cycle Works, K&N Air filter, Fuse block, stainless steel valves & reg/rect from Oregon MC Parts. Raptor CCT, XJ air shocks, 850 FD, Sportster mufflers, Standard handle bar, Tusk Bar Risers, SS braided brake lines. Cat Eye speedometer. HID projector beam headlight, LED running lights.Comment
Yesterday I rode the north portion of the loop I suggested. What a hoot. On Father's Day weekend, I met 4 cars running south from 26 on 53 to Moler, then south on the Miami-Foley road to 101. Tighter than 22, fun ride.1980 XS 11 Special: The King of Kong, 9th wonder of the world. Pacifico fairing, chopped shield, Yamaha hard bags, Diamond seat, T-Kat fork brace, XJ top end, YICS Eliminator, '80 carbs from Spyder Cycle Works, K&N Air filter, Fuse block, stainless steel valves & reg/rect from Oregon MC Parts. Raptor CCT, XJ air shocks, 850 FD, Sportster mufflers, Standard handle bar, Tusk Bar Risers, SS braided brake lines. Cat Eye speedometer. HID projector beam headlight, LED running lights.Comment
Two irregularities are showing up now and then. 1) the headlight relay is slow kicking in, and 2) a couple of cylenders drop out. I let it idle for a second, rev it a couple times, and we're good again. Happens in the dry as well as wet conditions. I replaced plug wires about 10 years ago. May be time for some different coils, or there's a wire problem.1980 special (Phyllis)
can't make it
This year, but next year if the timing is right, I'm all over it! Going to run North America on the E with a Pacifico. Plan to hit Andreas, Crazy Steve and TopCat for sure and hit every rally in between. Need a knee replacement before though.mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186Comment
I may have spoken too soon anyway. I still don't have the building permits for the new workshop/garage. I'll be lucky to start construction by the 15th...
I plan to make it an annual event if it takes off...
Wishing you well, Tony. My garage is now open if needed. Plenty of bike parking space here too, plus room for tents in the front yard, lots of camping near by, and the coast is cool.1980 XS 11 Special: The King of Kong, 9th wonder of the world. Pacifico fairing, chopped shield, Yamaha hard bags, Diamond seat, T-Kat fork brace, XJ top end, YICS Eliminator, '80 carbs from Spyder Cycle Works, K&N Air filter, Fuse block, stainless steel valves & reg/rect from Oregon MC Parts. Raptor CCT, XJ air shocks, 850 FD, Sportster mufflers, Standard handle bar, Tusk Bar Risers, SS braided brake lines. Cat Eye speedometer. HID projector beam headlight, LED running lights.Comment
