Early Spring To-Do List
    • 4015
    Contemplated saving for an ST, but when I thought of everything, I realized my baby deserves more loving than any other bike in the stable.
    So . . . :
    -Touch-up tank and engine paint
    -Petcock rebuild (using kits this time)
    -Muffler replacement
    -New R/R from Tony
    -New front & rear tires
    -Oil/filter change
    -Seal all cover gaskets with "The Right Stuff"
    -Valve lash check
    -Rear Air shock replacement
    -Swap Molex connectors for Weatherpak?
    -Fog light switch mount change
    -R6 Caliper/New Rotors
  • DeanR
    • Jan 2005
    • 1499
    • Finger Lakes NY
    Do both Ian! A few of us have found these two bikes to be just the ticket.
    80 SG
    81 SH in parts
    99 ST1100
    91 ST1100
      "Early Spring"?
      My repairs/upgrades during the winter help to keep my enthusiasm going, and I have more time without lawn care, gardens etc.
      I am guessing your garage is not heated? Kerosene heater are better than nothing (I installed a natural gas heater).
        • 4015
        Insulated, not heated. But, I'm in no rush to get my list done. I know most of the list is a one-day event.
          Hi Ian,
          Not too fast we have to get through the DEAD of winter first.
          • TADracer
            • 1417
            • Kenner, Louisiana USA
            Check List
            I have a handy Spring tune Up checklist I made up several years ago. It is in PDF format so most any computer can open and print.
            It goes through every group and system on the bike in a logical order (logical for me anyways ) A few items are specific for my machine. For instance, adjusting the cam timing and setting the carb floats to 1mm (I have slotted cam sprockets and ZRX carbs) but those lines can be skipped.
            Anyone interested, send me a PM with your email and I will gladly send you a copy. Keep your old copies and they become a great maintenance record for your machine.
            Mike Giroir
            79 XS-1100 Special
              • 4015
              I have a TON of bikes Dean, including modern sport bikes. My Hayabusa has been on a few LD trips quite comfortably. I guess it's wants over needs. Next bike purchase will be a newer bike for a bargain price. With the next set of mods, I'll be content for another riding season on a great bike that I know like the back of my hand.
                • 4015
                Hi Ian,
                I hear yah Phil, but my job(s) keep me busy along with a girlfriend that gets eveey other spare minute. With the rate the New Year is flying, my To-do list will be something I'll need to do with a quickness when the time becomes available.
                  • 4015
                  First day to start working on the bike!!!
                  If everything goes well, the agenda today is as follows:
                  -Clean starter, and install new brushes
                  -Clean contacts in ignition switch
                  -Petcock rebuild
                  -Buff/polish mufflers
                  -Install new jets, set float height
                  -Measure airbox for new K&N panel air filter
                  -Tap handlebar riser holdown for mounting of switch housing
                    • 4015
                    Cancel those plans! Just broke my side cover in-half due to the cold. Going back home to pout.
                      ANY heater in the garage would be a help at this point, wouldn't it? I think I would HAVE to put in a heater if I lived back there, as I spend a LOT of time "tinkering".
                        • 4015
                        I was geared-up to pull the parts and transport them to a shop to work. A simple pull on the side cover snapped it. I guess I will not attempt anymore disassembly till the temps become more stable.
                          Good call Ian. Too damn cold to even contemplate being in my garage.
