Hey Brant,
Sorry about the OLD thread, that issue was fixed a few months ago as I showed in the thread/photos. I understand I think what you meant with regards to the spark plugs...having only used single platinum vs. double platinum?
I picked up the new Knock Sensor and plug, but another problem cropped up. I had noticed that the car seemed to not just quickly crank to life, but seemed to crank a few more revs before it would catch. When I stopped at NAPA for the KS/connector, and went to go home, the starter barely turned enough to finally crank the engine....and right afterwards I got a whiff of that magic smoke escaping smell.....I got out, lifted the hood, etc., but nothing seen, so I went on home, but left it running. I then performed the test procedures I needed to do....checked the charging system....14.3 volts=good...and no ALT warning light! Turned engine off. Then LOAD TESTED the slightly more than 2 y/o battery....tested fine...didn't drop below 11 volts for the 300-500 CCA load test for 10 seconds!
SO....having ruled out a weak battery, that left me with just a burning up Starter motor! So...I went to the A.Z. and got a rebuilt replacement, and also dinner! Took me ~2 hours to drop the old one, and put the new one in, so I couldn't make it back to the A.Z. for the core charge and starter test before they closed tonight. BUT, the new starter works just fine NOW.
I'm thankful for all of the diagnostic training I've received here at Channel 11, applies to vehicles other than just our bikes!
, got it and installed it, hooked everything back up, and LUCKILY the engine ran correctly again hitting on all 6.
Sorry. Don't know how I missed that. All I have in defense is that sometimes I do drink in the evenings... lol. Glad you seem to have sorted it out.
, the plugs so deep down into the engine due to the double overhead cams, that it's almost not worth it to try to do that type of diagnostic approach.
Leave a comment:
