New old guy......
  • Bikes
    • Oct 2014
    • 174
    • Coastal Maine
    New old guy......
    Greetings from coastal Maine......wasn't sure where to post an intro.....figured this was as good a place as any.....
    Forty some years riding, just picked up bike number 26 ...a 1980 xs1100g with twenty thousand miles, wasnt running,,po said it wouldnt start after raining.....charged the battery, replaced the main fuse, pump and prime....bingo! Hittin on all four......all for a couple hundred bucks.....
    Gonna clean up the tank, repaint(red), pod filters, acct mod, all lubrication, tune up, wires, new fuse panel, probly tires, I'm sure more will pop up......anyway, I've learned a lot here, many thanks, i had been a professional auto mechanic most of my life so not afraid to dive in......hope I can contribute here and there....here she is....
    My daily rider...until the xs11 is ready......
    I know, i know......this was my daily until last spring.....
    Thanks and looking forward to ridin......
    Mark
    1980 xs1100g 3H5.......
    1992 Ducati 907ie
    2001 Moto Guzzi Jackal
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    Nice score
    Mark, could not have done better on that deal !!!!! Can't wait to hear your progress.
    If your lookin for lifetime filters K&N, if you don't want to spend that much the UNI pods, if you want the best all around find a stock air box and put a K&N in it. But you knew that
    Welcome ! Don'e
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
    • Prisoner6
      • Aug 2013
      • 1184
      • Phoenix, AZ
      WELCOME to the forums, Mark!
      Feel free to ask any questions as you progress with your bike ... someone here will have the answer ... the collective knowledge available here is astounding!
      Marco
      1979 Honda CBX
      2002 Kawasaki ZRX1200R
      WE MISS YOU, DON
        Good buy on the G. Other than the aftermarket bars and exhaust, that looks to be a pretty unmolested bike with nearly all of the hard to find stuff present.
        Welcome!
        • Bikes
          • Oct 2014
          • 174
          • Coastal Maine
          Welcome ! Don'e
          Thanks.....i do have the oem airbox....its in good shape.....not sure what I'll do at this point but i like the pods...cleans it up....better breathin....
          I do have a question.....can the plug wires be changed on the oem coils? I have good spark but the wires look toasty....
          Mark
          1992 Ducati 907ie
            Good running at ALL rpm ranges AND performance are better accomplished with OEM airbox. It ALL works together for BEST performance, including OEM airbox. No power to be gained from pods, just more intake noise.
              ...I do have a question.....can the plug wires be changed on the oem coils? I have good spark but the wires look toasty....
              Yes, they can be replaced.... http://www.xs11.com/forum/showthread.php?t=137
              ... but new Dyna or Accel coils will give a real performance improvement. And how the wires look isn't an indicator of how well they'll work; these are solid-core wire, not carbon core. Most issues with them is the connection between the wires and the spark plug caps, or the caps themselves, and the caps can be replaced. If you have 15K ohms between the plug wires (with the caps off, give or take 2K ohms), the coils are good. The caps should read 5K ohms each.
                • 2005
                All those bikes look good. Good score on the xs11 and welcome aboard. Good luck on getting it going. Looks like it has a solid exhaust on it.
                • Bikes
                  • Oct 2014
                  • 174
                  • Coastal Maine
                  What I got so far.....
                  Feedback please.......
                  Compression 120+ all four...Changed oil and mid and fd lube.....replaced the fuse box and main fuse, pulled all connectors, clean and grease, replaced plugs, removed and cleaned out carbs,(#1 was the worse one, as always) set the butterflies evenly...floats all even, inlet valves work fine, fixed the pick up coil wires(two front(top) ones)....fires up, charging 13.6, skipping jumping for a few minutes, warmed up, not hitting on all four, shut it off, check a couple things, start it up, now it is hitting on all four..but..still doesn't "feel"right....take a quick outlaw run down the road, pulls good but needs the revs to be smooth...
                  Got back idle too low, turn it up (who ever put that there ought to be shot)
                  Still has to clear itself off idle....I'm guessing I have to be more thorough syncing the carbs.....gonna pick up my carb tubes this week and sync it up better...
                  Am I missing anything?
                  All the lights and switches work....horns worked once then took a hike....gonna clean the switch gear next weekend...
                  No clutch problems or first gear jump....and the brakes work....yea......
                  I dig these big fours cylinder bikes....
                  Mark
                  1992 Ducati 907ie
                  • donebysunday
                    • Oct 2012
                    • 1737
                    • New Berlin, Wi.
                    Do the valve clearance then sync the carbs with the new tool.
                    The idle slowing down after a ride says fuel is not clean. A can of Berrymans or Chevron Techron in the full tank left to sit for a week or more. Then drain the fuel system, dispose of dirty fuel (don't put dirty fuel in any other). Clean carbs again add inline fuel filters close to the carb Ts so they act like sediment bowls, fill with fresh fuel try again.
                    76 XS650 C ROADSTER
                    80 XS 1100 SG
                    • Bikes
                      • Oct 2014
                      • 174
                      • Coastal Maine
                      Cleaned the carbs again, fresh fuel....warmed up, adjusted mixture, synced carbs....runs excellent!.......nice idle, snaps up good, no misses.....pipes sound nice.....
                      Valves o.k.
                      Now that I know its a runner, time to replace worn stuff, paint and polish....get ready for spring....
                      Seat cover and low rise bars are on the list so far.....
                      Thanks....
                      Mark
                      1992 Ducati 907ie
