High Temp Powder Coat
    Has anyone been able to find a gloss black high temp powder coat? All I've seen is flat black on the high temp stuff. I was wanting it for some headers.
    • 6753
    Its out there Tod...I found this site quickly enough...
    1980 XS650G Special-Two
    1993 Honda ST1100
    • XJOK2PLAY
      • 2099
      • Skiatook, Ok.
      Tod,
      If you can't locate any, you might give Rod Brakhage a call.
      He does powder coating, ya know.
      Pretty sure he could help ya out.
      I have his number, if you need it.
      Bob
      2011 Kaw Concours 14 ABS
      • SFerinTEXAS
        • Jun 2006
        • 876
        I was looking into these a while back.
        Cerakote is a global leader in the manufacturing of thin-film protective ceramic coatings. Specialized finishes for Automotive, Aerospace, Industrial, Consumer Electronics, Sports & Fitness and more. Browse our Gallery, locate a Certified Applicator, or contact us about your coating needs.
        http://www.cerakotehightemp.com/ copy and paste
        79SF
        XJ11
        78E
        • Arthur_of_Hex
          • Oct 2014
          • 89
          • Bangor, ME.
          X2 on the cerakote. We spoke to a firearm dealer up the street who actively uses cerakote. We are in the process of getting quotes on exhausts for our builds, if we can get a good exhaust sample shoot from them I'll definitely share.
          Matt
          81H Rebirth/Custom Build
          1st Gen RX7; Audi quattro; Wrangler JK
          PanikSwitch Cycles - Brewer ME
          http://s48.photobucket.com/user/Arth...201100%20Build
            • 6753
            this stuff looks excellent...
            1993 Honda ST1100
              I've seen an exhaust with a high-temp ceramic coating and it's pretty fragile. It may be temp resistant, but not friction. Just a normal installation onto the bike marked it up pretty noticeably. It's NOTHING like powder coating for durability, which is dang near bullet proof. I'd just never seen gloss up to this point for the high temp.
              That Caswell doesn't give any specs that I see besides a 450 degree cure at 20 minutes. I wonder what it s max service temps are. Considering the temps that chrome turns blue at... it'd have to be much higher than that 450.
                • 6753
                I saw 1000 degrees on the Caswell stuff...prolly not good enough...i merely posted that as an example of how quickly i found something on the net...it seems its not as easy to find as one would like...a glossy black high temp coating that will hold up to everything...
                1993 Honda ST1100
                  There's some rattle can stuff that withstands even higher than that, but... it's rattle can stuff. It seemed to hold up about as well as the professional ceramic coated stuff.. meaning not very well. The center headers get sandblasted behind the front wheel on a fairly steady basis, and nothing I've tried withstands that for very long. It was maybe a year or so ago, but I'd searched for a long time and never seen any high temp gloss, so apparently there's some stuff now coming out. BUT since I hadn't been able to find any before.. was the reason for my posting.
                  So.. I was thinking of either sending them off to Jet Hot, while I have a good solid system still, (Seem to be getting about like hen's teeth.. even worse for the XJ) to get done in their "Chrome" or try to look some more for a gloss black that would take the heat. Haven't decided yet and was just looking at options still.
                    • 6753
                    You also might consider adding a fender extender that would keep alot of that road crap from contacting the headers in the first place...good luck finding what you want...
                    1993 Honda ST1100
                    • donebysunday
                      • Oct 2012
                      • 1737
                      • New Berlin, Wi.
                      I guess I'll be 1st to try this Duplicolor 2000° paint, flat black like stove paint goes on first then a gloss clear. Both are 2000° finish, what would U-ALL suggest for prep. sand blast, soda, glass bead, just to get the chrome ready to accept paint ?
                      76 XS650 C ROADSTER
                      80 XS650 G Special II
                      https://ibb.co/album/icbGgF
                      80 XS 1100 SG
                      81 XS 1100LH/SH DARKHORSE
                      https://tinyurl.com/k6nzvtw
                      AKA; Don'e, UD, Unca Don'e
                        Along with some curb finders, whitewall tires, handlebar tassels, etc...
                        • XJOK2PLAY
                          • 2099
                          • Skiatook, Ok.
                          If yer lookin' fer a whitewall... ya might check with Ivan and see if he still has that Dunlop from Eureka Springs...
                          I'm sure you could convince him ta part with it!
                            • 9980
                            He tried to give it to me 3 years ago when I had a flat on the rear on the way to The Lost Rally. Even offered to deliver it.
                            It's gotta be getting some age on it.
                            • XJOK2PLAY
                              • 2099
                              • Skiatook, Ok.
                              HaHaHa!
                              That's funny!
