New to XS11! Hello from Wisconsin
  • xfoxrider8x
    • Jun 2014
    • 5
    • Madison, WI
    Hi all . Young XJ1100 owner here ! From Madison, Wisconsin area .. Hope to rebuild my bike in a few years. For now no huge plans, other then having to adjust valves and carbs.
    Great place here on the forum! I've been gathering much knowledge from all the willing mechanics that have the patience to teach the newer generation.
    Excited to get this beast of a bike running top notch !
    1982 XJ 1100
    Guten Morgen !
    Hey! Welcome to the forum, foxrider!
    You are going to have fun with your XJ!
    • CRXSi90
      • Jun 2004
      • 400
      • Madison, Wisconsin
      You came to the right place, you will soon be surrounded by lots of people who are super knowledgeable about these bikes. Just a heads up - I ain't one of 'em. But if you ever need an extra set of hands or anything, give me a shout since I'm also in Madison.
      '81 XS11H Venturer - holed up in storage while life happened since 07/08/04
      '81 Kawasaki KE175 enduro - 63 mph of smokey fun, now with collector plates!
      • Prisoner6
        • Aug 2013
        • 1184
        • Phoenix, AZ
        Welcome!
        Guten Tag, Isaac!
        And WELCOME to the forums!
        As you have already seen, this is the place to be for all things XS/XJ11 ... the collective knowledge here is amazing!
        Enjoy!
        Marco
        1979 Honda CBX
        2002 Kawasaki ZRX1200R
        WE MISS YOU, DON
        • Yahman
          • Mar 2008
          • 779
          • Salem, OR
          Welcome Isaac, the answers to all of your XJ questions can be found here.
          Ride safe,
          Larry
          82 XJ1100
          80 XS1100G (Project bike)
          64 Yamaha YA-6
          77 Suzuki TS-185
          • xfoxrider8x
            • Jun 2014
            • 5
            • Madison, WI
            Great to hear ! I am in the process of adjusting valves. I will soon be posting about possible shim swapping with anyone that has shims laying around.
            Is there anything I should do ? other then valve adjustment, cam chain tension, carb sync, possible middle and final gear oil change
            1982 XJ 1100
            Guten Morgen !
            • alaskey2
              • Apr 2014
              • 271
              • 60940
              Welcome! And if you're ever up ****s creek in Chicago I'll do my darnedest to help!!!
              78 E
              • Yahman
                • Mar 2008
                • 779
                • Salem, OR
                You might want to pull the final drive to check and grease the splines on the shaft. Also maybe check the headstock bearings.
                Larry
                82 XJ1100
                64 Yamaha YA-6
                77 Suzuki TS-185
                • CRXSi90
                  • Jun 2004
                  • 400
                  Great to hear ! I am in the process of adjusting valves.........
                  So you decided whether to pull the cam or use the shim removal tool?
                  • xfoxrider8x
                    • Jun 2014
                    • 5
                    • Madison, WI
                    Larry
                    Sounds like a good idea ! What splines exactly ?? the ones on the shaft by #37 ?
                    most likely getting the tool . i don't want to mess with timing if I don't have to. although I would like to see what the valves look like but that would require a new head gasket.. hmmmmm
                    1982 XJ 1100
                    Guten Morgen !
                    • Yahman
                      • Mar 2008
                      • 779
                      • Salem, OR
                      Yes, the splines on the end of shaft number 35, they fit into part number 11 on the final drive. I like to use Honda Moly Grease, part number 08734-0001. It contains 60% Molybdenum and is designed for drive shaft splines & other final drive components. Also use that stuff to grease the splines on the left side of the rim that engage the final drive output,
                      Ride safe,
                      Larry
                      82 XJ1100
                      64 Yamaha YA-6
                      77 Suzuki TS-185
                      • MPittma100
                        • Aug 2011
                        • 2359
                        Welcome to the forum. You will be glad that you stopped in. There is much information for you here. Everything is covered by a large group of knowledgeable and experienced XSives here.
                        Not a lot of information can be had from me on your XJ as I have only the XS experience. There is a grease fitting at the final drive end of the swing arm that is supposed to lubricate those splines on the XS bikes and I assume on the XJ also. It has been deemed by all members of the forum that this grease fitting does not properly lube the splines.
                        Service manual says to apply 30cc of grease. One stroke of a grease gun is one cc. Do the math. That is a lot of grease. But removing the FD to lube the splines manually is a sure fire way to know that is done properly. You will also see what shape the splines are in.
                        Removing the cams to adjust the valves is one method. I disagree with this procedure as there is too much that can go wrong and it is too time consuming.
                        If you do not already have a ACCT on the cam chain, you should think about putting one on. Do a search here and you will see the benefits and procedure. If you do decide to replace or adjust the manual one, you must follow procedure exactly in order to avoid getting the cams out of time and resulting in bent valves.
                        Good luck with your new project and again - Welcome.
                        Mike
                        1981 XS1100H Venturer
                        K&N Air Filter
                        ACCT
                        Custom Paint by Deitz
                        Geezer Rectifier/Regulator
                        Stebel Nautilus Horn
                        EBC Front Rotors
                        Limie Accent Moves On In 2015
                        Mike
                        • xfoxrider8x
                          • Jun 2014
                          • 5
                          • Madison, WI
                          Mike
                          Thank You ! Read somewhere that that grease fitting puts grease on the outside of part number 11 coupling not on the splines where its supposed to go .
                          I was looking into getting a ACCT .. I read to get one off a 85 venture if possible ? also read that I may have to file the bolt holes to get an exact fit .. was yours a plug and play ??
                          1982 XJ 1100
                          Guten Morgen !
                            No mod needed if using the Venture self adjuster. The splines in question DO get lube from 30pumps from grease gun in spite of the naysayers. Your choice.
                            Mine has never been removed from new, when I bought it. Very doubtful to have lasted this long and 80+K if it weren't getting lube. In fact, it will start pushin' red Conoco Super-Sta lube out around the 4bolt mounting flange if over done.
                              • 2095
                              Welcome, to add to your list, go over all your brakes from MC's to calipers and adjust the levers also.
                              These bikes are heavy and fast with dated brake systems and anything less than A1 condition will increase your odds of an unsafe incident happening.
                              Lube everything, change the fork oil, clean and use dielectric grease on all electrical connections, spend all your time your not working on your bike and read, read, and read some more threads on what your working on ATM
                              Oh, almost forgot your bike will run better if you post a pic or two
