The wonders of Pine-Sol
  • mikubuilder
    • Jul 2011
    • 548
    • Westland, Mich.
    To start with: ultrasonic cleaner is at my work, part of my "fringe" benefits
    As to Pine Sol, looking at ingredients it has acid in it, so probably strips some of the finish off, I also noticed copper colored deposit on walls of the dip tank...
    Nick
    1982 Virago 750 (it's alive!)
    • Cobia
      • Jul 2007
      • 1587
      • Palm Beach County, Fl
      I tried the Pine Sol dipping technique to clean the carbs but the acid in it stripped the protective finish on the carbs, made them porous and more prone to corrosion. It did clean them and changed the color, but in order to stop the propensity to corrode I had to find something to stop that process.
      I needed an alkaline to neutralize the effect of the corroding acid. After some research I found that vinegar would neutralize that. I soaked the rack in vinegar and that did the trick.
      1980G Standard, Restored
      Kerker 4 - 1
      850 Rear End Mod
      Automatic CCT
      1980GH Special, Restored
      '82 XJ1100 (Sold)
      • dpotter58
        • Aug 2004
        • 1866
        • Southern Maryland
        Vinegar is an acid
        1980 LG
        1981 LH
          All I know is that I took the carbs from my current project, and put them into my USC with Pine-Sol in it and they came out clean as can be. I m sure I rinsed them out with water, and dried with compressed air. So far, they look great. That was in mid December.
          I also took the set form the GSX600 I worked on over the summer and soaked them in Pine-Sol, I did not break the rack down so no USC. That set also came out nice, clean and looked great when I sold the bike a month later.
          • Newbee
            Truly XSive (Deceased)
            • Jul 2011
            • 160
            • Whitby Ontario, Canada
            Cleaning rusty parts
            http://www.youtube.com/watch?v=QOx5URgjTiU Other ways to clean parts.
