Hello all, new here, need help!!!
  • der verge
    • Dec 2013
    • 18
    • Lake Orion, Michigan
    Hello all. I am a long time, avid motorcyclist. I picked up a 1100 late fall, as a rescue bike. The long and short is this, I have been through the carburetors ad nausea. The jets are clean, the passages are clean. I installed new floats, new carb holders, and new diaphrams. I welded up the few holes in the exhaust, so it is all good there. I balanced the carbs, although the bike is not running correctly. 1 and 4 are running fine. 2 and 3 backfire at low engine speed. Crank the throttle, and she screams. All jets match across all carburetors. Unless there is some magical idle jet passage I am not seeing here, the bike should run tip top. I boiled the carburetors last night, and no change! Engine timing is set properly as well. To be honest, I am just flat out of ideas, and need help. If I cannot figure this out, I will have to part her out........
    Where to look guys? could this be a bad coil? I know 1 and 4 run together, as 2 and 3 do. Never seen a bad coil cause back fire at low speed, just flat dead miss.... HELP!!
    Thanks from snow covered MI!
    Current bikes....
    '01 Suzuki SV650/s
    of times past.....
    '79 Yamaha XS1100 SPL
    78 Yamaha DT 400
    84 Yamaha YZ 125 X 2
    01 Yamaha R6 Champions ed.
    79 Yamaha XS400
    70 Honda Trail 70 X 4
    01 Suzuki Katana 600
    83 Kawasaki KZ 750
    85 BMW K100
    97 BMW F650
    12 BMW G650GS
    01 BMW R1100R
    03 BMW K1200LT
    I am sure I have forgotten at least one.....
    • 8928
    You most likely have a broken pick up coil wire under the ignition cover left side of engine. Here is the fix...
    • der verge
      • Dec 2013
      • 18
      Yep, took me 20 seconds to find it.
      Thanks a ton!!!
      Current bikes....
      '01 Suzuki SV650/s
      of times past.....
      78 Yamaha DT 400
      79 Yamaha XS400
      83 Kawasaki KZ 750
      85 BMW K100
      97 BMW F650
      12 BMW G650GS
      01 BMW R1100R
      03 BMW K1200LT
        • 8928
        No problem brother, welcome to the forum.
          • 8074
          You've been at this for a long time, so you know most carburetor problems are electrical.
            • 2101
            Another One Saved . . . YESSS !!!
            • MarkD
              • Jun 2013
              • 488
              • N. Michigan
              Welcome, fellow Michigander. These guys here know their stuff. Would like to see some pics of your ride when possible.
              79 F
              1967 Suzuki X6 Hustler
              1973 Suzuki TM 125
              1979 XS1100 F
              2005 Kaw. Vulcan VN800
              1991 BMW K75
              • Prisoner6
                • Aug 2013
                • 1184
                • Phoenix, AZ
                WELCOME to the group, Layne!
                I've only been here a short time, but I've yet to see a question posted that the "collective" couldn't answer. Some very knowledgeable people here.
                Marco
                1979 Honda CBX
                2002 Kawasaki ZRX1200R
                WE MISS YOU, DON
                • der verge
                  • Dec 2013
                  • 18
                  That is hilarious!
                  I will get some pictures up when I get a chance to take one or two. The bike is quite torn down at the moment. She needed much clean up. Had to pull the tank, remove a bad lining job, weld a pin hole that became softball size, and many other little things. I will have her on the road by spring. And by spring I mean mid February. You know, just after the snow stops and the temps just begin to climb.
                  Current bikes....
                  '01 Suzuki SV650/s
                  of times past.....
                  78 Yamaha DT 400
                  79 Yamaha XS400
                  83 Kawasaki KZ 750
                  85 BMW K100
                  97 BMW F650
                  12 BMW G650GS
                  01 BMW R1100R
                  03 BMW K1200LT
                  • mikubuilder
                    • Jul 2011
                    • 548
                    • Westland, Mich.
                    welcome
                    make sure you hit me up, when you're ready to ride
                    or for any help if you need...
                    Nick
                    1982 Virago 750 (it's alive!)
                    • slow mo
                      • 858
                      • ontario canada
                      Thanks a ton!!!
                      don,t feel bad took me months to find that out and only because a friend on this forum called me then visited me and fixed the problem!!!,
                      The Belfast Express {1980 xs11oo special/TC fuse box/mikes xs pods/bad boy horn!/mikes green coils/mac 4 into 2 exhaust/ standard bars/vetter fairing c/w ipod CD iphone am/fm radio/tkat fork brace ,,,tuned by tinman
                      moemcnally@hotmail.com
                      i AM THE KING OF NOTHING
                      the people here are great , doesn't matter about the bike really/hamjam ////
                      • Gallaecus
                        • May 2011
                        • 254
                        • East Haven Connecticut
                        welcome
                        welcome to the site.
                        I have never seen another site where the people are more knowledgeable, experienced and willing to help you.
                        brought together by a common passion for an Epic motorcycle....the XS11....
                        ride safe...
                        Steven
                        1981 XS 1100 LH
                        1979 XS 1100 SF
                          • 4012
                          Yes, welcome to the forum. My family is from Livonia. Represent it well!
                          • der verge
                            • Dec 2013
                            • 18
                            So, broke out some wire and the old solder rifle. Bike used to misfire on 2 and 3. Now it misfires on 2,3, and 4!
                            I guess I will be rebuilding that entire wire harness.......
                            To the my new, local friends. I will meet up with you all in the near future I am sure. I am VP of one of the local BMW clubs, and therefor spend most of my time on two wheels. We will have to meet for breakfast sometime....
                            Current bikes....
                            '01 Suzuki SV650/s
                            of times past.....
                            78 Yamaha DT 400
                            79 Yamaha XS400
                            83 Kawasaki KZ 750
                            85 BMW K100
                            97 BMW F650
                            12 BMW G650GS
                            01 BMW R1100R
                            03 BMW K1200LT
                            • slow mo
                              • 858
                              • ontario canada
                              not sure this will help but the coils service 2 specific cylinders each you may have the wires reversed,, the wires that go to your spark plugs!! some one who knows much more than me hopefully will chime in and help,, ride safe slow Mo!
