JB Weld on gastank?
    • 6760
    JB Weld on gastank?
    Bought this Honda civic cage to save gas on my commute and now I find the gas tank has a leak on its bottom side. How well would JB weld work to plug a hole
    about 2/3rds the size of a dime?
    1980 XS650G Special-Two
    1993 Honda ST1100
  • jwhughes3
    • 2798
    • Home of the Alamo
    Temp repair until you can fix it right by replacing it.
    Gas tanks are usually easy to remove and replace if empty.
    John
    '81 XS1100H - "Enterprise"
      • 6760
      Temporary is what I'm looking for... definitely not a permanent solution...Getting all the gas out of it before attempting to patch tank...won't take it out...too much rust...Thanks John
      1993 Honda ST1100
        Hi Madmax,
        JB weld by itself might fall out from vibration from that large of a hole.
        Here is a bodge.
        Get a wallboard anchor, the sort that has 2 little legs you poke through a hole and they spring out inside then you do up the screw to tighten it.
        And a fender washer.
        Put the fender washer on the wallboard anchor.
        Slather the side of the fender washer that will face the tank with JBweld.
        Shove the fastener legs through the hole and let them spring out inside the tank.
        Tighten the anchor screw so the washer tightens onto the tank and the JBweld squishes out.
        Let the JBweld set up before you put gas in.
        Should hold OK until the rest of the tank rots out.
          • 7804
          Better still, your local auto parts store may have some purpose made putty to fix that leak.
          • mharrington
            • 407
            • Holland MI
            JB Weld turns into mush from gas exposure! The auto parts store has specific products. Ive used this with success but the area needing repair must be dry!
            nail hole filler image
            Seal-All® —
            Gas & Oil-Resistant Adhesive
            The contact adhesive and sealant that's the Mechanic's Choice. Seal-all adheres with superior strength to all substrates and materials except paper, cardboard and Styrofoam™. In a class of its own, the "repair-kit-in-a- tube” is ideal for automotive and garage repairs. Available in 2.0 and 1.0 fl oz carded packaging.
            • Practical: Seal-All is resistant to gasoline, oil, paint thinner, and most solvents.
            Seal-All is also water resistant immediately upon application.
            • Thin Formula: Seal-All is a thin adhesive.
            • Quick Dry: Perfect for all your craft needs. Sets in 2-3 minutes.
            Fully cures in 2-6 hours.
            • Waterproof: Use to decorate craft projects in and around water.
            • Paintable: Paint over for UV-resistance.
              • 6760
              Interesting fix Fred...I. will want something that is resistant to gas and other solvents...so my question about jb weld was bourne from ignorance. Thanks for all the replies folks...will be heading to the autoparts place tmrw.
              1993 Honda ST1100
              • MarkD
                • Jun 2013
                • 488
                • N. Michigan
                + 1 on seal-all. Good stuff for fuel leaks.
                79 F
                1967 Suzuki X6 Hustler
                1973 Suzuki TM 125
                1979 XS1100 F
                2005 Kaw. Vulcan VN800
                1991 BMW K75
                  Scroll down and read everything it's good for. I've used this stuff for years. Any auto parts store or Walmart carries it. I've used it under oily conditions out in the middle of nowhere when I punched a hole into my crankcase on the dirtbike. That was 2 years ago and it's never leaked. I've punched a small hole in the bottom of my fiberglass boat on a sharp rock and dove down to install it in the hole under water. Years later, it still never leaked a drop. You won't have to drain your gas tank and it'll be a permanent fix. Even with the gas dripping, knead it together like Playdough for a couple minutes, then smear some into the hole, then build a quarter sized patch around it.
                  I thought about trying to use it on a broken float post. Seems impervious to about everything that I've thrown at it. I try to always carry some in my tool bag on trips. Maybe next time we'll try it on Greg's ribs?
                    • 6760
                    Thanks Tod..sounds like that's just what I'd want
                    1993 Honda ST1100
                      • 6760
                      ebay price with shipping is a ripoff...but locally at Advaned Auto its 6 bucks...
                      1993 Honda ST1100
                        Hi Max,
                        If JBweld don't stand up to gas by all means use a better suited compound as a sealant but stop by the builder's supply store
                        on your way to buy that better class of goop because I reckon you still need the wallboard anchor and fender washer
                        What I'm worried about is the size of the hole you are trying to fix.
                        A hole "3/4 the size of a dime" is just over a half-inch in diameter.
                        An unsupported blob, even of stuff that gas won't touch, has a good chance of falling out of that big of a hole.
                        That's why I suggested the ol' fender washer and wall anchor trick.
                          • 6760
                          Hi Max,
                          I've only ever fixed pinholes and solder works for that.
                          If JBweld don't stand up to gas by all means use a better suited compound as a sealant.
                          Hey Fred...i think perhaps a combination of your method with the quiksteel will fill the bill...and the hole is more like a 1/4" around...there is considerable rust on this tank and i am concerned that using an anchor bolt... as you describe it...would futher damage the area that is already compromised...the main deal is just to plug this well enough that it stops leaking and then i will just sell the car... to really repair it right is prohibitively expensive.
                          1993 Honda ST1100
                          • donebysunday
                            • Oct 2012
                            • 1737
                            • New Berlin, Wi.
                            Yes JB Weld is fine with oil but with gasohol E 10 it will melt, have not tried it with real fuel ? Believe it or not super glue is resistant to gasohol. Maybe you can find a way to use this, bolts,gaskets or what ever ? Also on my 79 silver trans am I just used stuff from the auto parts store and never had a problem.
                            76 XS650 C ROADSTER
                            80 XS650 G Special II
                            https://ibb.co/album/icbGgF
                            80 XS 1100 SG
                            81 XS 1100LH/SH DARKHORSE
                            https://tinyurl.com/k6nzvtw
                            AKA; Don'e, UD, Unca Don'e
                            • TomB
                              • Aug 2006
                              • 967
                              • Cumbria, UK
                              I've been repairing fuel tank leaks for years using simple fibre glass matting and resin, when I say years I mean I've done a few and the've been on for years, '94 Ford car and VW bus/camper.
                              Wire brush the tank, paint with resin, apply glass mat, apply more resin. I have the Ford with tank repaired 10 years ago, still Ok now. Why do a temp repair, make it permanent for a few $$
                              Tom
