Hello XS11.com
    • 9980
    Originally posted by Insomniac
    Yeah that didn't take long. I got her running on all four and the transmission does shift fine now. I apologize for blowing up your forums, I am just excited about my next project. I will send photos and have questions along the way.
    Thank you
    Heh heh........it's your forum now too.
      Thank you
      Excellent!!! I love it when a bike comes back to life. From the looks of things you now need to work on the WHOA, meaning the brakes. Seeing both front calipers tied up would indicate they were locked up and needed to come off to move the bike.
      • Insomniac
        • Aug 2013
        • 11
        • Eugene, OR.
        Yes it came to me like that. The rear brake sounds like my ex wives voice, so I will tear it down also. The front master cylinder is dry and from your guys past experience and from theory.....the brake fluid absorbed moisture for the last thirty years, leaked out and the water left behind seized the calipers and master? If thats the case, are they rebuildiable, or are these items on the just replace the brake system?
        80 SG
        "Some cause happiness wherever they go; others, whenever they go."
        - Oscar Wilde
        • Rasputin
          • 3192
          • Lacombe, Alberta, Canada
          The ones in this link were rebiuldable so yours should be as well.
          However if the rust is bad enough they may have gotten too far gone. Good time to invest in S/S brake lines as well.
          2-79 XS1100 SF
          2-78 XS1100 E Best bike Ever
          • ViperRon
            • Feb 2011
            • 1062
            • Woodstock, VA
            Welcome aboard. Another issue with these bikes that comes up from time to time is clutch slippage. If the bike set for a long time it is possible to have build up of some light rust within the plates of the clutch. It can cause slippage or grabbing causing you to have to change adjustments. Its not a big deal to take off and clean just do a search in the forum for clutch and get a good understanding first. TC has a pretty good pictorial of the dissasembly.
            Rodan
            1980 G Silverbird
            1198 Overbore kit
            Grizzly 660 ACCT
            Barnett Clutch Springs
            R1 Clutch Fiber Plates
            122.5 Main Jets
            ACCT Mod
            Mac 4-2 Flare Tips
            Antivibe Bar ends
            Rear trunk add-on
              The brake system is very simple. The caliper has a seal that sits in a groove. When the brakes are applied, the piston sort of rolls the seal, and the seal brings the piston with it when it rolls back as the brake is released.
              So, you will want to get the pistons out, remove the seal, and clean the groove really well. Sometimes the pistons themselves can get very pitted. Those may need replacing.
              The rubber parts are typically reusable. Just need a good cleaning. Who knows if they have been dry since 86 though.
              On the MC, there are two holes from the reservoir to the cylinder. One supply and a smaller return hole. Both need to be cleaned.
              • Yahman
                • Mar 2008
                • 779
                • Salem, OR
                Thank you Larry, I have found the right site and people to help make this bike what it should be.
                Incredible build on your friends 79 XS1100SF !! Seriously, Incredible job, looks amazing. What is the paint you used on the motor? Seems to have the perfect matte finish and look.
                Thanks, I worked on that bike for almost 2 years, but It was worth it. Just so everyone else knows what bike we're talking about.
                I used "PJ1 Coatings Fast Black engine and case paint". I purchased it from Z1 Enterprises at this link. I used a total of 2 cans.
                http://www.z1enterprises.com/ItemDet...item=TU53-6022
                Larry
                82 XJ1100
                80 XS1100G (Project bike)
                64 Yamaha YA-6
                77 Suzuki TS-185
                  Make that $500
                  - - - One of my friends purchased a storage locker and sold this 1980 XS1100 special to me for $250. - - - is there something I should look into first? - - -
                  Hi Robert,
                  first, before you spend any money, make sure you have a clear title.
                  Next, while 27 years old is real good for a girl, a 27 year old tire is a hardened brittle ruin of a thing that you shouldn't ride on.
                  Take another $250 and buy baby a new pair of boots.
                  • Insomniac
                    • Aug 2013
                    • 11
                    • Eugene, OR.
                    Hi Robert,
                    The first thing I did was contact DMV and find out if I could even get a title, they gave me an 'affidavit to establish financial interest in a vehicle', and said there would be no problem, being I provide a bill of sale. Sounded to good to be true but after asking a few car wholesalers, they said it is that easy here in Oregon. I still have my doubts, but will find out soon enough.
                    I have picked out tires, ss brake lines, pads, needles and seats have also picked out accel coils, because I remember spark issues with my RD and coils cured that....just waiting to slow down in my shop to get affidavit notorized.
                    One thing about these KS owners.....you guys must really like working on carburetors Do all of you install inline fuel filters? Because I imagine everything will be attracted to get hung up in the seat and let the fuel just flow and flow.
                    80 SG
                    - Oscar Wilde
                    • GLoweVA
                      • Jun 2011
                      • 1957
                      • Virginia Beach, VA.
                      YES on the inline filters!
                      I'm not sure what I'm more jealous of, the steal on the bike or that awesome shop you've got to work in.
                      +1, definitely get the title worked out before you drop a dime on anything else.
                      I love those bags. (Shoei ?)
                      80G (Green paint(PO idea))
                      The Green Monster
                      Got him in '04.
                      bald tire & borrowing parts
                      Scarlet
                      Got her in '11
                      Ready for the twisties!
                      81H (previously CPMaynard's)
                      Hugo
                      Cold weather ride
                      • ruffrider
                        • Mar 2008
                        • 60
                        • Stanwood, Washington
                        Welcome
                        Wow! A great deal and you found the right forum to learn all you'll need to know. You're gonna love your XS. They are great bikes.
                        1979 XS 1100 SF(16k now, more to come)
                        140 mains, 42.5 pilots, drilled airbox w/uni fliter
                        MikesXS Coils- bypassed ballast resistor- new wires
                        1975 GL1000 Gold Wing(81k-Old Faithful) and another 75 GL1000 project. MBS sickness for sure.
                        Other Bikes Iv'e owned:
                        1979 Kawasaki 750 LTD
                        1980 Kawasaki 125 Enduro
                        1975 Honda 400f
                        1976 Honda CB360
                        1968 Honda 160
                        • CaptonZap
                          • Jun 2010
                          • 1748
                          • Denver
                          Great buy!
                          Do you have to have the bike physically inspected, or just provide the paper work, in order to get title?
                          CZ
                          • Insomniac
                            • Aug 2013
                            • 11
                            • Eugene, OR.
                            Great buy!
                            CZ
                            I was told the affidavit is all that is needed. It does make sense to need an inspection, just no one has brought that up yet.
                            80 SG
                            - Oscar Wilde
                            • CaptonZap
                              • Jun 2010
                              • 1748
                              • Denver
                              Thanks for the reply,
                              Keep us posted on the procedure, as there are a number of people who could benefit from a simple titleing method for our "parts" bikes.
                              CZ
