Wheelie
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    Wheelie
    What do you do when the front wheel points at the stars ?
    Here is what happened to me,,,,
    Finished my ride 40 mi. out to try the good gas again same thing 29 out with the gas from 20 mi. out and 39 on the way back with gas from 40 mi. out.
    Then I thought I'll just go down behind the industrial park for a little 1/3 mile easy run up.
    There is some guy with his lites on in my lane ?
    I Slow and go to the far right, he has a girl at his rt. side door ( she looked pretty good ). Looks like he is getting ready to run his 80 something Mustang, huge tires and spun aluminum rims, sure nough. She steps out with a red scarf and I pull up even with his front end.
    She drops the scarf and I hit it, early lead my rear tire spinning just as I'm going for second the tire hooks up and the front end points at the stars, I've shifted into second just from the motion I think. I hit the foot brake without releasing the throttle the front end came down smooth as can be. I kept it up to 4th. then let off in 5th. there is a sharp right at the end and then stop sign. Cars are passing I can't pull out, 5 sec. later the Mustang shows up behind me. Cars go by and I leave he follows then turns off the next block. I go home. What a thrill !!!!!
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
  • Crusty Snippets
    • Sep 2010
    • 428
    • Gabriola BC
    Wheelie
    Well done.
    Touch the back break and keep the gas on and it worked.
    Lean a bunch forward, forget the brake and keep the gas on.
    Not so easy to do with the high bars.
    My Yami has not lifted the front wheel yet, maybe I am being to kind to it.
    I am usually a bit gentle in first and second, and put more power on in the higher gears.
    I will save my best wheelie story because it is your moment.
    Unkle Crusty
    • donebysunday
      • Oct 2012
      • 1737
      • New Berlin, Wi.
      Originally posted by Crusty Snippets
      Well done.
      Unkle Crusty
      OH come on let's hear it !!!!
      Changed the bars to LTDs but still pulled them down so my mirrors were looking at the ground. Tightened the bars as much as I could, after.
      76 XS650 C ROADSTER
      80 XS 1100 SG
      • kflyboy
        • Apr 2012
        • 81
        • Lakewood, Colorado
        That's Sweet. Bet he was suprised.
        • WMarshy
          • Apr 2009
          • 2402
          • Mexico NY
          I have one for ya... I was working the evening shift and got out at midnight, the night was warm and figured I'd zip through town and see how many college partiers were out on the streets bar hoppin. Happened to turn my head and see a group of ladies who are laughing hysterically and appear to be watching me pass by. I wasnt quite sure if I was the but of their joke or not...could have been the little red cooler on my back seat interrupting the sexy lines of the bike, idk... in an attempt to regain some dignity I down shifted from second into first and immediately proceeded to clutchup a healthy wheelie and ride through the upcoming intersection, shifted to second and set it down at the following intersection. At that point I took my next right to get off the main street, joged a few back streets to the gas station and parked for a few minutes to let the adrenaline wear off and to listen for sirens. Likely not the best time or place for that but I couldnt help it, man what a rush!
          '79 XS11 F
          Stock except K&N
          '79 XS11 SF
          Stock, no title.
          '84 Chevy K-10 "Big Blue"
          • donebysunday
            • Oct 2012
            • 1737
            • New Berlin, Wi.
            Let's hear more
            I want to hear more, I want to take on my buds V-rod. I've ridden the V-rod before the mods he did and I know he will walk me in the industrial park dragstrip just want to know by how much ? ? ? Or should I just forget it ?
            76 XS650 C ROADSTER
            80 XS 1100 SG
              Forget it..........they are sub- twelve sec. out of the box.
              • Pizzaboy
                • Jul 2013
                • 16
                • Oshkosh, Wisconsin
                Sub 12 second..??
                Learn how to do just about everything at ehow. Find expert advice along with How To videos and articles, including instructions on how to make, cook, grow, or do almost anything.
                I guess these are sub 12 second too.
                Anybody know what the RWHP and Torq would be on a 81 Venturer?
                81 H Venturer
                  Originally posted by Pizzaboy
                  http://www.ehow.com/list_7452165_spe...ha-xs1100.html
                  The fall of 77' with PeeWee Gleason(rode all manufacturers bikes for braggin' rights..110lbs. soakin' wet and was a professional quarter miler on bikes) did the 11.79sec. on the then new XS11 prior to production release. With a bunch of little Jap engineers all around dialing that bike in its every move, tire pressures, suspension settings, carb dial-ins, etc. With that said, 'joe' public, no matter how experienced from a launch to that 60ft. mark(which makes or breaks a good quarter mile run) can not make that happen. Have heard a couple folks here claim super low 12's, but I and several other old and treacherous competative drag racers know better. As far as RWHP and torque of an 81, whether it be a Special or Venturer is gonna be below the 78's power, still quick enough to get a performance award. Years back I run my Venturer fully dressed at the local strip here, which is at 5,000ft. elevation. Didn't 'cowboy' it hard off the line, and the clutch would 'turn loose' a bit in third. but still respectable high 13's and low 14's. That was with .435 reaction times, and ALOT of cage experience off the lights, and LOTS of gate drop experience on moto-x bikes. That was a first for me at the strip on a street bike. That 'barn door' on the front sure came into effect part way into third gear.
                    • 3917
                    There have been other posts on here regarding wheelies, and I think I agreed with someone when they said it was a 30+ year old bike, that is also heavy. I'd hate to see that think come down with all it's weight and do any damage to the frame or anything else.
                      BTW, the Venturer weighs in a 680lbs. with half a tank of fuel.....yes, I've weighed it. Heavy scoot to overcome inertia. Another thing......any mid 13's is still some 15-18 lengths from any high 11sec. run that was originally done. My times only produced 97-102mph speeds and fourth gear last 300 or less feet from finish, which doesn't give time enough for R's to come back strong with the 'whole barn' on the front and tallest shield available(25").
                      • Pizzaboy
                        • Jul 2013
                        • 16
                        Probably still faster than alot of "rubs" out there. I'm not a Harley Hater, Hell, I love my 00 883 hugger....with 83 Rwhp But I cant see spending 20,000 on a bike, Well maybe if every other debt I had was paid off, and I could swing Cash for it....Sorry off subject. I agree with you on the testing. Speed is Power to weight. I saw a video on Youtube, some dude had a XS putting out a 107 hp on dyno....might be fun to pick up another engine....do some massage work, and see what could happen?
                        81 H Venturer
                          On my trip back east a couple years ago, I was loaded down pretty good including an ice chest on the back. I had assorted stuff in the cooler including a half gallon of milk. We'd ridden all day and the contents in the ice chest were sitting in an ice slosh. The three of us pulled up to a stop light next to a guy riding a 'Busa with a gal on the back. I pulled up next to him, and jokingly revved the motor, laughing, KNOWING there was NO WAY I could even come close to that bike. I just wanted to see him launch the thing. The light turned green.. and then he started easing away from the light. I thought, "I've got one more chance to see him go..." and I dumped the clutch and launched. The front wheel came up high, but not enough to have to let off the throttle. I smacked 2nd and the wheelie came down about halfway through 2nd and I let off the throttle. I was proud of the old girl.. making a showing for me even at it's age. I was thinking how cool it must have looked from behind.. chest puffing with pride.
                          Ivan told me later, laughing, that when I launched, he saw the girl on the back of the 'Busa dig her fingernails into the guy's ribs as a warning not to race... then told me that apparently the milk had leaked into the cooler, because as I was in a wheelie, a nasty, milky, froth of water was pouring out of it, looking really rediculous.. lol.
                          Pride cometh before the fall.
                          • jwhughes3
                            • 2798
                            • Home of the Alamo
                            Tod that is the funniest thing I have heard all day...
                            John
                            '81 XS1100H - "Enterprise"
                            • Crusty Snippets
                              • Sep 2010
                              • 428
                              • Gabriola BC
                              Wheelie
                              [QUOTE=donebysunday;414417]OH come on let's hear it !!!!
                              Was at the Isle of Man in 1971. Night time and a cop was directing traffic with a lit torch ( flash light ) A kid popped a wheelie and knocked the torch out of the cops hands with the front wheel.
                              I did hundreds of endos when riding cross country races thru the mountains of BC.
                              At the local track ( Westwood near Vancouver BC ) the big race of the year is when the visiting hot shoes including the number one plate show up.
                              After the start everyone waits anxiously to see who will be first around.
                              At the start I ( national number 14 ) lined up with the hot shoes. The bikes are not geared for wheelies, rather top speed down the back straight.
                              But the stars and moon must have been aligned as I got a hole shot with the front wheel off the ground in first to about 50mph, then it barely lowered as I hit second to about 85mph.
                              First around to everyones surprise was number 14, and again for the first several laps.
                              Then the number one plate passed me on the inside of the off camber turn three sweeper. I thought that's impossible, and that must be why he has the number one plate. Think his name was Paul Allen. He later worked for Dunlop Tyres. Not sure if I was running gumballs in those days.
                              Unkle Crusty
