Desulphator
    Desulphator
    Capton Zap included this:-
    One I can recommend is http://batteryminders.com/store.php?...home&&app=bike
    It has a 5 year warranty, and you just plug it in and don't forget to unplug it before you go riding.
    I have used one to reclaim some marginal batteries. According to the factory engineer, the desulfator is on constantly.
    in another post.
    OK then, HTF does a charger know if a battery is sulphated and WTF does it do to fix it?
  • Tat2demon
    • Jun 2012
    • 718
    • Sioux Falls, South Dakota
    Nate
    78 XS11 "Matilda" 2H7 000364
    K+N Air Filter
    88 Voyager XII
    81 XJ650 Maxim
    • CaptonZap
      • Jun 2010
      • 1748
      • Denver
      in another post.
      It's f***in magic!
      I'm no battery engineer, but here is my take on it.
      A battery will accept a certain amount of current at a certain voltage if the plates are clean. When they sulfate, the sulfate acts as an insulator, which reduces the current at a given voltage. And the specific gravity (SG) goes down, since the sulfur is bound up on the plates.
      So the desulfator starts applying pulses of high voltage to the plates, and the pulses dissolve the sulfate, which returns to the sulfuric acid, and the battery accepts the charge and the SG increases. The battery Minder guy says that they are using radio frequency pulses. I know that a light bulb and a diode hooked to, what you folks up there call mains, line voltage will send half wave DC into a battery and do sort of the same thing, sort of.
      I don't know if you have access to Bing up there in the frozen wastelands of the North, but a search for "light bulb battery charger" will get you to some info on that sort of "poor mans" charger. Aww hell, you probably have frozen fingers and can't hit the right buttons, so here is the site. http://www.alpharubicon.com/elect/3dollarbattggn.htm
      There are groups of tech geek's that roll their own desulfators, up to and including making their own choke coils. There again, Bing is a portal to all that esoteric knowledge. Just get someone with warm fingers to type in "desulfator" and go from there.
      Nice and warm here in the Southland, CZ
      • Courtney
        • 542
        • Nanaimo BC Canada
        We don't call them mains, that's those crumpet chompers across the water. We use the same terms you 'Mericans do.
        Bone stock 1980 Special except for the exhaust and crashbars. Oh yeah, and the scabbard for the Winchester Defender.
          "sufficiently advanced technology is indistinguishable from magic"
          Hi Zapper,
          Arthur C Clark said that.
          Thanks for the link. Effin' simple once you know the trick of it, eh?
          BTW it's only brass monkey weather up here 5 months a year.
          FYI, last night we had to drag out our portable air conditioner to get the bedroom down to a reasonable sleeping temperature.
