Close call
Close call
Nate
78 XS11 "Matilda" 2H7 000364
K+N Air Filter
88 Voyager XII
81 XJ650 MaximTags: None -
Whoops, meant to put this in the lounge.Nate
K+N Air Filter
88 Voyager XII
81 XJ650 Maxim -
Yikes! I would need to be cleaning some things up after that.....Nathan
Theodore RooseveltComment
I have locked up my rear by downshifting to far before.
But, yeah, that was a first you say it, then you do it moment!!!!
78 XS750Comment
Just got back from a short 12 mi. ride, this same thing just happened to me only my rear brake works my front left as well on the 81LH. Got slowed enough to miss his little Ford Escape and time to hit the high beam right in his drivers side window ( my head light is bright ) man he was looking right into the light and quickly turned his head away. Bet he saw black/red or maybe white for awhile. Seemed like he pulled out on purpose. Kept watching to see if he would turn around and follow but nope, I just kept going, did not really feel like doing the Morgan knocker anyway.76 XS650 C ROADSTER
80 XS650 G Special II
https://ibb.co/album/icbGgF
80 XS 1100 SG
81 XS 1100LH/SH DARKHORSE
https://tinyurl.com/k6nzvtw
AKA; Don'e, UD, Unca Don'eComment
I don't think it was tire smoke, no tire marks on the pavement. I think that was the mist from him pissing himself!!!!
78 XS750Comment
I have had the rear locked up, got a little sketchy, but managed to avoid a collision!Richard
'79 XS1100SF "Phantom Stranger" full fairing w/radio and cd player, H-D Roadking trunk, everything else stock
'02 Honda VTX1800CComment
Wow... Work on those brakes then. Or better yet, get some stainless lines. On extreme panic stops, my bike basically is doing a stoppie anyway with the back end hopping around up and down off the ground, so back brake is useless at that point, but still, you should be able to skid with the back no problem.Try your hardest to be the kind of person your dog thinks you are.
I had 4 instances last fall alone when people pulled out in front of me and I put it into a rear slide. Very easy to lock it up, even with my original rear brake lines.Nate
K+N Air Filter
88 Voyager XII
81 XJ650 MaximComment
If you can not lock up the rear wheel there is a problem like Trbig says fix your brakes. With the leverage available on the foot pedal and the advantage of hydraulics working the piston, the forces it would apply to the rear brake are incredible.
I had a buddy who used to lock up his front brake on a 81MNS at 70Mph on the highway just to show off his riding skills. It was impressive to see until you thought of how dumb it was.
While these brakes are not world class they are sufficient enough to get the job done very well.2-79 XS1100 SF
2-78 XS1100 E Best bike Ever
Couple of more parts bikes of which 2 more will live!Comment
Nate
K+N Air Filter
88 Voyager XII
78 XS750Comment
