View Post
New Toy....
47 Ford
Ford started putting hydraulic brakes in the 38 delux and all models in 39.
Your car would have had a 221 cu side valve ( flat head ) 24 stud engine, with the water pumps back on top of the heads. Likely had a 2 barrel model 97 carburetor. The distributor was probably up high rather than down low in front of the engine. Suspension would likely be the transverse springs that let the cars roll a lot. Solid front axel that helped many shimmy a lot around 80mph. Horsepower would be around 85.
The three speed gearboxes liked to jump out of second and many engines overheated. The rear end had probably progressed from using key ways.
So there was a lot of ancient technology in some very pretty lines.
They used Bedford Cord on the seats of many cars.
Headlining was usually a wool material rather than cotton. Wool was better.
Good plan to replace the engine, tranny, brakes and rear end on the early Fords, which is what I did with my 37 Ford hearse. However I left my 33 stock.
Unkle Crusty
