Bought a Colortune
  • WMarshy
    • Apr 2009
    • 2402
    • Mexico NY
    Bought a Colortune
    Cant wait to receice delivery of my new Colortune 500 I picked up on ebay. I couldnt pass the opportunity up, it has the nice hard case and eveything delivered for less than $40. Im curious to see what I will find once I hook it up.
    '79 XS11 F
    Stock except K&N
    '79 XS11 SF
    Stock, no title.
    '84 Chevy K-10 "Big Blue"
    • 8904
    You will find that it probably works ok if you have aftermarket coils, not so well with the weaker OEM units. Use it in the evening with low light, much easier. JMHO
    • WMarshy
      • Apr 2009
      • 2402
      • Mexico NY
      Thanks for the advice Phil. I plan on getting Accel coils eventually.
      Im interested to see how much the burn changes based on ambient temperature. Early in the season it little lean when in the 40's but seems right on when the temps improve to about 60F. I'd be more confident in making changes for cold weather with this tool. Next on the list is a Carbtune. Or just finish making my home-made version.
      '79 XS11 F
      Stock except K&N
      '79 XS11 SF
      Stock, no title.
        From my expereince, the colortune is a great tool to get you in the right field of the ball park. It often will have a miss to it. You can tune to the right color, but it still needs fine tuning.
        I always get the flame in the rich/yellow area, then tur the fuel down till it is getting a nice bunsen blue, then back out about 1/4 turn toward yellow. But I still look at my plugs to fine tune it, and the vacuum readings on the morgan.
        • dpotter58
          • Aug 2004
          • 1865
          • Southern Maryland
          mine sparks around the plug rather than a strong spark to the center
          1980 LG
          1981 LH
          • Tat2demon
            • Jun 2012
            • 718
            • Sioux Falls, South Dakota
            Mine does too after I use it for a while. I fill it up with carb cleaner and scrub the hell out of the insides with a tiny wire brush and it works good again after that.
            Nate
            78 XS11 "Matilda" 2H7 000364
            K+N Air Filter
            88 Voyager XII
            81 XJ650 Maxim
            • WMarshy
              • Apr 2009
              • 2402
              • Mexico NY
              I gotta say, my first impression of this thing is it seems flimsy and cheap (tube and mirror). Im glad I didn't buy one at full price. It should work fine as long as I dont get too ham handed with it.
              '79 XS11 F
              Stock except K&N
              '79 XS11 SF
              Stock, no title.
              • TADracer
                • 1417
                • Kenner, Louisiana USA
                I rarely use mine, which was left over from an old MGB my wife had (really crappy car). It is hard to see in daylight even with strong coils so here is what I did.
                Take a piece of 1" plastic conduit or pipe about 12" long and cut a slot up one side to allow the spark extension to pass through. Start the motor and when ready to view the Colortune, place the conduit over the plug and look into the top. Makes a nice, dark tunnel to see the flame.
                Mike Giroir
                79 XS-1100 Special
                • Tat2demon
                  • Jun 2012
                  • 718
                  You should really only be using that to get the threads started. With our 11s there is no need for the mirror.
                  Nate
                  K+N Air Filter
                  88 Voyager XII
                  81 XJ650 Maxim
