DVD recorder
  • red bandit
    • 970
    • central michigan
    DVD recorder
    I have a DVD player that doesn't always work so I ordered my first DVD recorder. Do I use DVD R or DVD RW to record TV shows? Without getting to technical because I won't understand, what is each used for and what is the + and -. Is + record and - play? Thanks RB
    79 SF parts bike.
    • 8930
    DVD-RW re-writable is a waste of time IMHO, the R one time disks are far more dependable and are inexpensive. As for the + or -, check your owners manual, it will tell you which one is compatible with your unit.
    No, it is two slightly different types of disks.
    • red bandit
      • 970
      • central michigan
      OK, it says it will use both + & -. So do I understand you correctly, the R is a one time record, I can not record over the old "show" repeatedly? I am looking for something I can record stuff on repeatedly. ie: record this show/event tonight, in a couple days record something else on or over what I previously recorded. Like you used to be able to do with VCR tapes.
      79 SF parts bike.
        A RW disc can be recorded over, but it's not as simple as a VCR. While a tape can just be recorded over, a CD-RW or DVD-RW needs to be erased first, a separate step. There's even two ways to do that; full erasure (slow process), or just remove the 'table of contents' info (fast) but the latter leaves 'stuff' behind that can degrade new recording. The discs do go bad if recorded over a lot.
        A TiVo or similar machine would be a better choice....
        • red bandit
          • 970
          • central michigan
          When you say a full erase is a slow process what kind of time frame are you talking about?
          79 SF parts bike.
            Basically the same amount of time that you recorded on the disc, sometimes less. That can vary between disc drives; I've seen some that can erase 2 minutes in 1 minute, but for some it's a 1 for 1 ratio.
            • red bandit
              • 970
              • central michigan
              So if I erase after I watch the program I should be good to go for the next recording. Thank you very much. You guys are great.
              79 SF parts bike.
                Don't be surprised if the discs fail fairly quickly. While they're 'rewritable', I've seen some go bad in as few as ten sessions, others last for months. And you won't always know they're bad until you try to record on them...
                • red bandit
                  • 970
                  • central michigan
                  I won't be doing a lot of recording, once a week would be a lot. I didn't want to get only one recording on them. Thanks again for all the info.
                  79 SF parts bike.
