Variable Output Switches
  • red bandit
    • 950
    • central michigan
    I have an automatic bullet casting machine and I want to be able to slow down the main drive motor (120v) when I run large bullets because the molds get too hot. I'm looking at Variable Output Switches and they are avalible in 1K, 5K & 10K ohms. Is that the amout that it would slow down the motor? I want to slow it to about 60-80% of full speed. Would I want the 10K? Any help is greatly appreciated. Thank you.
    Switch "B" is what I was thinking about using.
    McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
    79 SF parts bike.
    http://www.mcmaster.com/#speed-pots/=llyqq1
    Hi Bandit,
    potentiometers work by reducing voltage and it's not good for electric motors to run that way.
    What you need is a VFD, a device that reduces the motor speed by changing the current frequency:-
    Marshall Wolf Automation is an independent- and women-owned industrial automation distributor with in stock options from leading manufacturers.
      Fred is right. VFD is what you need to do it right.
      What kind of setup so you have for casting? I would like to see that!
      • CaptonZap
        • Jun 2010
        • 1748
        • Denver
        [QUOTE=red bandit;402135]I have an automatic bullet casting machine and I want to be able to slow down the main drive motor (120v) when I run large bullets because the molds get too hot.[QUOTE]
        The type of control is dependant on what type of motor the machine has.
        Is it a brush type motor, or induction type?
        A brush type can use a router speed control, and induction will need a variable speed drive.
        CZ
        • red bandit
          • 950
          • central michigan
          It's a Ballisticast commercial casting machine.
          I don't know if the motor has brushes or induction. I will have to check.
          The reason I asked the original question is the later machine has a potentiometer switch to adjust the speed. I'm not sure how slow it will go. That's why I was asking about the 1K, 5k or 10k. Maybe I only need to run 80% of full speed. I think 60% would be a little slow.
          router speed control, variable speed drive. Is one a potentiometer?
          79 SF parts bike.
            You want to be careful about running the motor slower. If you do have a 'universal' (brushed) motor, an adjustabe pot will be best rather that a multiple-output unit (a VFD won't work with a universal type motor). A VFD will be required for a brushless motor. Two caveats about doing this; if it's a brushed motor, make sure the switch is rated for at least 200% of the full load motor current as shown on the nameplate. Two, with either type the motor will likely run hotter at lower speed, so think about some sort of thermal protection for it so you don't burn it up.
            Electric motors really like to run at full/rated speed, running them slower with reduced voltage (particularly into a constant load) is hard on them. Generally, a gear ratio change to change speed is better.
              Hi Bandit,
              I googled ballisticast and viewed a video of a Mk 11 in action.
              I couldn't see what kind of drive motor it had but man, does that thing spit bullets.
              Do you run yours once a year or do you make bullets for your entire shooting club?
              What you could do at no cost and little effort is run a big fan on it, just like keeping the XS11 engine cool when you tune the carbs.
              And, since you ask:-
              guns, beer and bikes what more could you ask for.
              Wine, women and song?
                • 7605
                Looking at the site, it seems the company already uses a gear reduction. I could be wrong, but I've not seen many electric motors that run as slow as that one was. You should be able to buy a different gear reduction unit, with a different gearing, that will bolt up. Check Granger, or one of the big houses that handles bearings and motors.
                Let me know if you are doing 45, as I will need to reload once I get the part from Colt to repair my gold cup.
                • CaptonZap
                  • Jun 2010
                  • 1748
                  • Denver
                  If you were to call the company and ask to speak with an engineer, you could ask him if it is a Universal or induction type motor.
                  If it is a universal, as Steve pointed out, you will not need a VFD, as it changes the speed by varying the frequency of the input power.
                  My reason for suggesting a router speed control for a brush type motor is that all of the controls that I have played with are a pulse width modulation (PWM) type of supply, which means that the power supplied to the motor is composed of pulses of full voltage electricity, of longer or shorter duration, giving more or less total power, and which mitigates some of the drawbacks of voltage lowering arrangements typical with the rheostat (potentiometer) type controls.
                  Again, as Steve pointed out, whatever arrangement you come up with, monitor the motor temperature closely.
                  "Happiness is a warm gun" (Beatles, '68)
                  CZ
                  • Petersg_99
                    • Apr 2012
                    • 184
                    • Phoenix, AZ.
                    I would bet that the motor is a simple 120V motor that pretty much plugs into 120V. If so you can use a variac variable transformer. You do need to be careful about not overloading the motor for the voltage you're pushing, but this might do the trick for you...
                    http://www.amazon.com/Variac-Variabl.../dp/B006NGI8VS
                    Guy
                    1980 XS1100G - Frankenstein - resurrected from the impound lot
                    1991 Suzuki GS500E (not running yet)
                    2003 Burgman AN400 - Blue Belle
                    2005 Burgman AN400 - Silver Belle
                    • Petersg_99
                      • Apr 2012
                      • 184
                      • Phoenix, AZ.
                      Read their comment about variacs. make sure you size the variac for the current your motor needs...
                      Guy
                      • CaptonZap
                        • Jun 2010
                        • 1748
                        • Denver
                        It might be easier to find a tool speed control rather than a variac sized to his needs, since they, variacs, seem to have gone the way of discrete component electronics.
                        And there again, you are using reduced voltage as the control, rather than the reduced total power input of the PWM control.
                        Anyway, the first thing is to find out what type of motor it is, the rest of this is just us flapping our gums.
                        Makin' the best of a snow day,
                        CZ
                        • ViperRon
                          • Feb 2011
                          • 1062
                          • Woodstock, VA
                          If the manufacturer can not help or will not make a suggestion it might be helpfull to get the model and manufacturers info off the unit as well as the plate info off the motor. Then people here might get info off the web or be able to give a good solid suggestion. It may be an intirely different motor in the later model to allow speed change. A caution on trying to use a VFD or PWM with out knowing for sure what you have it could die even with a fan cooling it. Many modern motors have a thermal switch in the windings that will open to prevent fire. Some motors depend on a start circuit to get them to run speed quick and using a PWM could make them overheat. Some thermals reset and others are fused and most are hard to get to. If there is any way to change gearing in a transmission its a better solution that way you don't have to worry what type magic smoke is in the motor.
                          Rodan
                          1980 G Silverbird
                          1198 Overbore kit
                          Grizzly 660 ACCT
                          Barnett Clutch Springs
                          R1 Clutch Fiber Plates
                          122.5 Main Jets
                          ACCT Mod
                          Mac 4-2 Flare Tips
                          Antivibe Bar ends
                          Rear trunk add-on
                          • red bandit
                            • 950
                            • central michigan
                            Right now the only thing in overload is my brain. I appreciate all the info but you guys are way over my head. So I think I will call the manufacturer and see what they have to say so I don't burn something up. They have always been very helpful. I didn't see anything on the motor to indicate brushes or induction. However I did not see a place to change the brushes so that may be my answer. Yes it's a Mark ll. It comes with two fans on it and I've added another. Yes, it's a gear reduction and I don't want to buy another. A lot of work and money when I don't run many 405 gr bullets. I shoot competition and shoot at many clubs and sell to whoever wants them. Helps pay for my shooting expenses. Thanks again. You guys are great.
                            79 SF parts bike.
                            • Geezer
                              • May 2003
                              • 2985
                              • Willamina, Oregon 97229
                              I'll second Captain Zap, go look for a router speed controller. It'll do what you're asking for.
                              BTW, do you cast any .458" bullets? If so, I'd be willing to buy some for my .45-70...
                              Tony
