Variable Output Switches
    Originally posted by red bandit
    Right now the only thing in overload is my brain. I appreciate all the info but you guys are way over my head. So I think I will call the manufacturer and see what they have to say so I don't burn something up..
    That's the best solution....
    • red bandit
      • 955
      • central michigan
      I thought the mfg. called it a motor coversion switch, about 6 wires and $70. Does that sound familiar to any of you?
      79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box w/larger velocity stacks, 750 FD.
      79 SF parts bike.
        I thought the mfg. called it a motor conversion switch, about 6 wires and $70. Does that sound familiar to any of you?
        Without seeing the wiring diagram and the specs on the motor and switch, can't say for sure. But that sounds right, and if they're offering that as a factory part you're probably very safe. Just make sure you fully understand the connections before applying power so you don't let the factory smoke out....
        • xs11jack
          HALF GURU
          • Nov 2002
          • 606
          • O'Fallon, Mo.
          Just in case you want more info on your machine and casting in general go to CastBoolits.com. They have several experts on the machine you have. And have about 28,000 other boolit casters for advise.
          Ole Jack
          J.D."Jack" Smith
          1980G&S "Halfbreed"
          1978E straight job
          "We the people are the rightful masters of both congress and the courts, not to overthrow the constitution, but to overthrow the men who pervert the constitution." Abraham Lincoln
          Life is like a coin, you can choose to spend it any way you wish, but you can only spend it once. Make your choices wisely.
