Judging by it's apparrent age and the fact that it appears to be designed to pull someting up where it can be attached, I would guess some kind of harness tool.
You know now that you mention it I'm pretty sure I know what it is.
It's for handling some part of an old wood burning stove. The lids or opening the door to add wood.
When we lived in Newburgh, NY in 1969 the kitchen stove was ANCIENT, it had been converted from woodburning to natural gas. It had the round plates covering the burners, which you had to remove so you could light the stove. Man, it was like time travel. Anyway we had something like that thing to remove the plates and open the oven door and flue.
old coal stove shaker handle to shake ash from stove?
FOXS-XS11SG
I'm still asking around, but how about a brake spring compression tool?
It’s an old pin spanner wrench that was custom made for a specific purpose. The clip would allow it to be held in place while making fine adjustments to something while a jam nut would be used to lock the assembly in place when everything is just right and then the spanner would be removed and put away until the next time it is needed.
