xs650 or xs1100???
    My best guess is there is some dirt or debris on the VIN that makes it look like 2FO instead of 4RO. The 2FO is an XS650 VIN, but that is not an XS650 or an XJ650.
    Worst case scenario is someone altered the VIN as they only had a title to an XS650.
    • old_skool
      • Nov 2011
      • 554
      • Ohio
      You'd never get away with that in Ohio, you might be able to mix and match same cc frames but the Ohio State patrol does random inspections on bikes ( a lot of theft here) and they go over every detail on registration and vins and such, likely to get a bike confiscated. It's one thing to put a motor from one bike into another frame, but not try and pass off a bike as a whole other animal. Not saying any of this was done, just commenting on the possibility.
      81 XS1100H
        It could be done in Ohio. Again, not saying it has happened on this bike.
        But....if you wanted to say file down the downtube to eliminate the stamped numbers and then use a good punch set to re-stamp the numbers to match a title you have....well...how many LEOs know the difference between an XS1100 and an XS650 or an XJ650? In Ohio, engine numbers are never checked when you bring in a vehicle from out of state, let alone in state checks.
          Well, may as well and jump in on the guess'in. Looks like he's got a 79Special......why 79?.....can't be 81(no slotted rotors and no black circle recesses in side covers, and alot more). Not an 80Special(no slotted rotors again, and alot more). See it does have the Jardine 'sketti' pipes........and Jardine muffs. A 79Special it is......and I'm stickin' to it.
          • old_skool
            • Nov 2011
            • 554
            • Ohio
            Then it has the wrong frame, 79's didn't have the front frame mounted reflectors
            Frankencycle
            81 XS1100H
              I do, I do!!!
              • old_skool
                • Nov 2011
                • 554
                • Ohio
                Originally posted by nate moen
                I do, I do!!!
                seeeeee, and it's not the local Leo's but the state cops who are pretty knowledgeable in this area as they do regular vehicle inspections, not just commercial, and you never know who might be a MC enthusiast.
                81 XS1100H
                • Kingxs
                  • Jan 2013
                  • 10
                  • Houston, TX
                  the numbers are off of the Frame neck (# on the first post)and motor im thinking it may be a shady deal if you know what i mean. i just need to know due to parts reasons. i picked it up in a trade for a laptop and have always loved the midnight's. but i do have title which has that same number.
                  80 XS11 frankenbike
                  Love God, Love Your wife, Love Your Family and enjoy the Ride! Shinny side up!
                  • old_skool
                    • Nov 2011
                    • 554
                    • Ohio
                    what does the title say it is?
                    81 XS1100H
                    • Kingxs
                      • Jan 2013
                      • 10
                      • Houston, TX
                      its left blank just says its a 1979 yama mc thats it no model no weight
                      80 XS11 frankenbike
                        Well, it seems it would be tough to change the engine numbers, but perhaps the same thing was done there. Is it a plate that has been attached or can you clearly see the numbers are stamped into the engine case itself?
                        On the frame neck, there is a sticker on one side of the neck, and on the other side the numbers are stamped into the metal. IF all of those match that 2FO number, something is not correct here.
                        It is definitely an XS1100 Special model. I am not savy enough on the frames to guess if is 79, 80, or 81. It obviously has been put together from more than one bike IMO. The seat grab bar is definitely 80-81 Special, the rear tail light mounted up high is 80-81. And those yellow reflectors were on the 81, but not the 80. However, the left side cover is not stock to any XS11 I know of, no locking tab area.
                        How far does the speedo go, 160 MPH or 85 MPH?
                        • Kingxs
                          • Jan 2013
                          • 10
                          • Houston, TX
                          its not a plate it is stamped in on frame and motor with no sticker and it only goes to 85
                          80 XS11 frankenbike
                            Ok, and I looked closer at the pic and you do have slots in the brake rotors, so I still think it is a 4RO machine. Look at the TCI, the black box under the seat. see if it has a 2H7 stamped into it, or if it has a yellow tag on it or is otherwise marked with a 4RO.
                              • 2103
                              Nah...
                              ...not a '79.
                              In the first pic the slots in the front rotor can be seen at 4 and 6 o'clock
                              Also no kick start shaft.
                              I'm thinking '80 SG.
                              • Kingxs
                                • Jan 2013
                                • 10
                                • Houston, TX
                                2h7 on box
                                80 XS11 frankenbike
