Re:aftermarket throttle replacement
  • wildbill
    • Feb 2003
    • 346
    • western NC
    I`am thinking about replaceing the throttle on my bike{78E standard} with a after market type.While there is nothing wrong with what I have, it just looks bad.The kill switch does not work,same said about the starter button.The only thing that works is the light switch.I can move the light switch but am worryed about the throttle cable.Would I have to change it?What would be a good replacement?Anything that might suprise me if I do this?Thanks
    Bill Harvell
  • Geezer
    • May 2003
    • 2985
    • Willamina, Oregon 97229
    You'd have to adapt the wiring but there are several later modle Yamaha throttles that would work.
    Geezer
    • wildbill
      • Feb 2003
      • 346
      • western NC
      Geezer
      Thanks,that would keep me from having to change my throttle cable and posiably get the switches that don`t work would work if I do this.Might save me a few headaches.Thanks and keep the rubberside down
      Bill Harvell
      • wildbill
        • Feb 2003
        • 346
        • western NC
        Well I did some tinkering and adapted a starter button off my dirt bike on to my xs.It was not hard to do and the button is easy to reach.The starter button is a stand alone type with everything enclosed.I then plugged the hole where the stock button would go.Looks unusual but works good which is the main thing.Replaced the screws on the throttle ass.,one with a larger screw head and the one that holds the throttle cable in place with a 8mm head bolt with another nut to take up the slack.Still don`t have a kill switch yet but leaning toward not installing one.The bike still has the tipover kill switch so that should have the bases covered.What do you think of the update?
        Bill Harvell
