GM 4L60E gurus?
    GM 4L60E gurus?
    Anybody know about these trans? My LT1/4L60E swap in my Jag is not shifting right, I've checked all the electrical connections and the ATF level...
    It will shift from first to second but only at upper RPMs, freewheels when it hits third, and has no engine braking. Trans is a '94 version AFIAK...
    • 9980
    New trans or a rebuild Steve. High clutches are out.
      No chance for a bad connection or easily replaceable part?....
        • 9980
        Not in my experience
          Well, that's depressing....
          • WMarshy
            • Apr 2009
            • 2402
            • Mexico NY
            Should'a went with a manual...
            '79 XS11 F
            Stock except K&N
            '79 XS11 SF
            Stock, no title.
            '84 Chevy K-10 "Big Blue"
            • ManagerMike
              • Mar 2010
              • 445
              • S.E. Michigan
              If you aren't flagging any trans related DTCs, then it is likely a clutch issue. Does the speedo work? Do you have a scan tool? If so, with key on engine off, using trans output controls, turn on and off the shift solenoids while stethescoping the rear of the pan, you should hear a definite click as you command each one on. This will at least let you know the controller can operate the trans.
              '78 E "Stormbringer"
