WTF is this??
  • DAVINCI
    • Jan 2011
    • 1048
    • Cedar Mountain, NC
    WTF is this??
    Ever seen anything like this before? 2-yr old tire, 2000 miles on it. PLENTY of tread left. Sidewalls are fine. It's not isolated cracking, it's all over the tire. Bridgestone S11 Spitfire
    Overheating maybe? BTW, tire has already been renewed.
  • tv5150
    • 352
    • Central Tejas
    Date Code???
    Are you going by the date code on the sidewall or when you purchased it?
    If it's by the date code, I think I'd get back to the place you bought it from for possible replacement..Just sayin'
    Current Rides:
    02 GL1800 Wing
    79 XS1100SF Sold 10-15-12
    81 XS1100H Venturer Sold 10-27-12
      • 7761
      Is it possible that is was run low pressure?
      • DAVINCI
        • Jan 2011
        • 1048
        @Tv5150: date code. Independent shop = screwed. Bridgestone told me go pound sand.
        @marty - possible, but not long term. I'm pretty anal about those things.
        • tv5150
          • 352
          • Central Tejas
          Man, that sucks, guess I need to start doing a pre-mounting inspection on all tires when I receive them...
          Current Rides:
          02 GL1800 Wing
          • DAVINCI
            • Jan 2011
            • 1048
            There was nothing wrong with this tire when purchased, bike was always stored indoors. Two years later, this cracking shows up.
            • Irukandji
              • Apr 2011
              • 75
              being in NY I wouldnt think youd be riding in winter, but could they have been riden through any chemical exposure daily, other than salt?
                I've seen Avons do that in as little as one year, but not Bridgestones...
                • WMarshy
                  • Apr 2009
                  • 2402
                  • Mexico NY
                  I second the Avon part, mine is going into its third season and is showing sign of checking at the root of the tread... Luckily the tire is nearing the end of its life. I think its due to the rubber losing plasticisers... the greater the exposure to light/sun will increase its loss...
                  '79 XS11 F
                  Stock except K&N
                  '79 XS11 SF
                  Stock, no title.
                  '84 Chevy K-10 "Big Blue"
                    I don't know, I run the same tire on the rear of mine and haven't seen that even in the hot summer here, but I only get about 1 1/2 years out of the rear tire on mine (mileage is good, that's just how many miles I've been getting.
                      • 8628
                      Every Bridgestone S11 I've owned does that in less than 1 year, . Never had one fall apart <knock>.
                      • latexeses
                        • Jun 2008
                        • 1491
                        • California
                        They are biodegradable. Zero miles + 3 years = in the shredder.
                        Everything on hold...
                          • 6751
                          its called planned obsolecence...products that degrade before their useful life is up...good for manufacturers...bad for you...
                          1980 XS650G Special-Two
                          1993 Honda ST1100
                            I don't know if it's simply a bad batch or what, but it's not just Bridgestones. I've had Dunlops, Avons, and just now, a Shinko do the same thing with all being within a year or two of the date stamp. It makes me wonder if I simply got a tire made on a Monday morning right after a holiday or one on Friday before one? lol.
                            • ViperRon
                              • Feb 2011
                              • 1062
                              • Woodstock, VA
                              Could it have possibly been road chemicals. I ran thew calcium cloride one time that did that same damage to my tires. Some idiot was dumping it on a dirt road and at the end doing a U turn onto the highway.
                              Rodan
                              1980 G Silverbird
                              1198 Overbore kit
                              Grizzly 660 ACCT
                              Barnett Clutch Springs
                              R1 Clutch Fiber Plates
                              122.5 Main Jets
                              ACCT Mod
                              Mac 4-2 Flare Tips
                              Antivibe Bar ends
                              Rear trunk add-on
