New guy, first bike.
  • tv5150
    • 352
    • Central Tejas
    You can post an ad in the 'parts wanted' forum here, or search eBay for a set. Here's a pic of what yours should look like..
    These '78-79 units have been fully restored and powdercoated, so you probably won't find a set this nice...
    The '80-81 carbs will also fit; here's an identifier guide to help you look..
    Here's another possibility; this swap has been done successfully, so there's info on tuning.
    http://www.xs11.com/forum/showthread.php?t=35964
    WOW, those sure are purty...
    Do you mind if I copy and save? I want to print-out a 8X10,
    frame it, and put it on my nightstand so the 1st thing I see when I
    wake up is the glorious beauty of those masterpieces of metal sculpture
    Current Rides:
    02 GL1800 Wing
    79 XS1100SF Sold 10-15-12
    81 XS1100H Venturer Sold 10-27-12
    • tv5150
      • 352
      • Central Tejas
      Paint Scheme
      Ya know, when I 1st was it, I thought, what in the world has someone
      done to the paint on that bike, but now, everytime I look at it, I can
      see the vision like you spoke of it having a tri-five chevy look
      The rest of the bike is really in very amazing condition from what I see in the pics...once again, great find at a very reasonable price...
      Current Rides:
      02 GL1800 Wing
        Hey Tat,
        Great looking machine for sure. What folks haven't commented on is that those Non-stock carbs are uniquely mounted...the PO appears to have used PVC tubing or such to allow the wrong carb spacing to be adapted to fit onto the XS boots! I also do NOT see the vacuum advance hose going up the side of the engine to the carbs...so the bike may be running only on the Cent. Adv. curve which could also contribute less than optimal throttle response and behavior!? Provided your plugs don't look bleach white, then they probably won't HURT the bike, but your mileage will probably suffer a bit, norm is 30+ MPG, but can vary for a variety of reasons, no vac. adv. input is one of them! :EEK:
        • Tat2demon
          • Jun 2012
          • 718
          • Sioux Falls, South Dakota
          Hey Tat,
          Well after reading your post I had to run right out and check. Its a an aluminum tube in there. The pic just makes it look white.
          I see two rubber lines that run from the inner side of the outboard carbs. Neither is hooked to anything. This these would be the vac advance?
          Nate
          78 XS11 "Matilda" 2H7 000364
          K+N Air Filter
          88 Voyager XII
          81 XJ650 Maxim
            I'm going to borrow Terry's photo:
            Looking at the second carb from the right...there is a brass nipple just above in the intake mount....the same location on the other carbs are solid body, THIS is the vac. adv. port that should connect to a hose to the vac. adv. pot inside the left side timing cover.
            The other 2 hoses you speak of are connected to "T" fittings mounted between the outside carbs and the inner carbs...higher up on the carb body than the fuel inlet "T"s. These upper hoses are the carb bowl vent hoses, they can be left open to air...but bugs/critters/dirt can get in there. They are normally connected to the nipples on the AIRBOX to both provide venting, and to recollect what miniscule fuel vapors would be emitted back into the intake to be burned! Do NOT cap them off, either connect to the airbox, or put a little fuel filter on the end so they can breath, but not allow stuff to get into the line/carbs! And make sure the nipples on the airbox are also not clogged with dirt/oil, etc.!
              • 7828
              What T.C. said, except you do not HAVE the original air box. I WOULD look for a set of carbs, and plan on a rebuild next winter. First thing would be read plugs, and make sure they are NOT white but a light brown. You may need to jet a little on the carbs, and do NOT expect the full range power because they seem to be a bit smaller than the stock set-up, and probably will not flow the correct air/fuel mixture needed at all RPM's.
              Send a PM later, and I'll try to get into storage and see what I have available. I know I have at least one extra set of carbs, and I think an airbox as well. They would need work, but if it helps it's an option.
              Oh, and don't be surprised when a second bike shows up at your door. These are like potato chips, you can't have just one! Welcome to the madness.
              • Tat2demon
                • Jun 2012
                • 718
                Lol thanks guys. Ill have to go out in a bit and check it out. Im pretty sure the lines I see hanging down are the adv lines youre describing. Theres no T on them.
                Hopefully Im going to look at an 80 or 81 a friend knows about this afternoon. Says a guy has had it sitting in his backyard for 10 years and is wanting $150 for it. Could be a good parts bike.
                Nate
                K+N Air Filter
                88 Voyager XII
                81 XJ650 Maxim
                • Tat2demon
                  • Jun 2012
                  • 718
                  Heres the lines.
                  I cant see anywhere on the motor where they would hook up.
                  Nate
                  K+N Air Filter
                  88 Voyager XII
                  81 XJ650 Maxim
                  • 4rmotorsports
                    • Sep 2011
                    • 2
                    • Cleveland, Ohio
                    those do appearto be the float bowl vent lines. will not help you with your advance problem. i would assume you could T off of the vacuum supply going to your petcock and use that?
                    btw those carbs are the same ones my brother has on his 77' CB750. you might be able to sell them to get the money for the proper carbs.
                    1978 XS1100
                    2002 FZ1
                    • Tat2demon
                      • Jun 2012
                      • 718
                      Well the bike that I went to look at turned out to be a bust. What was supposed to be an xs11 turned out to be a mid 80s Virago 750.
                      Nate
                      K+N Air Filter
                      88 Voyager XII
                      81 XJ650 Maxim
                      • Tat2demon
                        • Jun 2012
                        • 718
                        Pulled the carbs off today to try fixing a couple leaks. It was a waste of time. However I did take some pictures to try IDing these carbs. Diverray is sending me a set of carbs and an airbox. Cant wait till they get here. After reassembling everything and seeing how loose the boots are, Im pretty sure the only things the current airbox is keeping out of the carbs is large rodents and birds.
                        Nate
                        K+N Air Filter
                        88 Voyager XII
                        81 XJ650 Maxim
                        • foreda
                          • 949
                          • Southwest Louisiana
                          Carb boots
                          If you need a set of carb boots I think I have a couple of nice sets.
                          Dale
                          78 XS1100E Standard
                          Coca Cola Red
                          Hooker Headers
                          http://i408.photobucket.com/albums/p...m/DSC00580.jpg
                          1979 XS1100 Special
                          http://i408.photobucket.com/albums/p...m/DSC00612.jpg
                          1980 XS Standard
                          http://i408.photobucket.com/albums/p...m/DSC01137.jpg
                          2006 Roadstar Warrior
                          http://i408.photobucket.com/albums/p...um/warrior.jpg
                          • Tat2demon
                            • Jun 2012
                            • 718
                            The new seat from Ebay showed up today but its missing a chunk of cowl, so the search for a stock seat continues.
                            Petcock kits came in last week but I messed up my back pretty bad Tuesday so I haven't been able to put them in yet.
                            The carbs from Diverray should be here Friday. Cant wait!
                            Nate
                            K+N Air Filter
                            88 Voyager XII
                            81 XJ650 Maxim
                            • jwhughes3
                              • 2798
                              • Home of the Alamo
                              filling
                              Nate -
                              could you back that cowl section with thin aluminum or better yet glue plastic to backside and fill that section in with body filler? them prime, paint and Bob's your Uncle...nobody's wiser till you get a replacement piece.
                              john
                              '81 XS1100H - "Enterprise"
                              • Tat2demon
                                • Jun 2012
                                • 718
                                That could work for a bit but there is currently no emergency to get the seats swapped. I just dont like the look of the touring seat. I can live with it until I can get this taken care of.
                                The seller got right back to me and is going to try finding a replacement cowl and send it to me. Hopefully someone on here has a spare they can part with.
                                Nate
                                K+N Air Filter
                                88 Voyager XII
                                81 XJ650 Maxim
