I did something really stupid.
  • XJfan1
    • Feb 2012
    • 180
    • Huntington,Indiana
    I'm having a charging issue with my xj. I ordered some new brushes for the alternator and I was trying to clean the copper plate they ride on. With the cover off I started the engine and was cleaning the grime off by lightly touching it with 1500 grit sand paper. Well apparently there is a plug in the bottom of the case that is held in by the cover. The bike ran for about 30 seconeds before the plug flew out at mach 9 and was followed by a blast of motor oil.luckily I was sitting in a folding chair and not on the floor.i quickly shut her off the began to hunt the plug that came out like a missle. I found it about 12 feet away and out it back in. lesson learned.
    1982 xj 1100
    "The Ape"
    http://youtu.be/AiQ8CqclHr4
  • petejw
    • 2269
    • sydney australia
    mate, dont feel to bad
    ur not the 1st person to do that.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • b.walker5
      • Feb 2009
      • 1745
      • Invercargill, New Zealand
      Yep, BTDT, got the stain on the garage floor to prove it.
        I have a saying "I like to learn from other peoples mistakes, keeps me from making them myself". This is one of those, if I had not read about it a few time sover the years on this forum I would never had thought that could happen.
        Glad it was just an inconvenience more than a "What happens when you let your bike run for ten minutes with no oil cause its all over the garage floor?" threads.
        • Hmar
          • Jun 2011
          • 100
          • Springfield. MA
          Haven't gone after the alternator yet, but when I saw your title I wondered "when did I post that?")
          1981 XS 11 special
          red
          40,000 miles
          • Danny Crawdad
            • May 2011
            • 239
            • Birmingham, Alabama
            I made a similar mistake with a dishwasher once. Those door safeties are there for a reason, evidently.
            XS11SH :: K&N Pods, 4->1, Dynojet kit, Barnett clutch springs, TC's fuse block, ATGATT
            Well, goodness. Look what we've got here.
            • CaptonZap
              • Jun 2010
              • 1748
              • Denver
              Originally posted by XJfan1
              I'm having a charging issue with my xj. I ordered some new brushes for the alternator and I was trying to clean the copper plate they ride on. With the cover off I started the engine and was cleaning the grime off by lightly touching it with 1500 grit sand paper. .
              Howdy,
              Here is another lesson that you may or may not have learned.
              Soft materials can get sharp, abrasive particles imbedded in them.
              Copper slip rings are soft.
              Abrasive paper particles are hard and, well, abrasive.
              When you use sand paper in copper, the particles can get imbedded in the copper.
              Now you have what is called a lap.
              Laps are used to grind things.
              Carbon brushes don't last long when run against a lap.
              Depending on the type of "sandpaper" you are using, the particles may or may not be electrically conductive. Garnet paper, true "sand" paper, is not conductive. Wet or dry usually has aluminum oxide grit, which is. This leads to arcing at the interface.
              Does the fact that you are looking for a stator have anything to do with your method of cleaning the slip rings?
              A rubber eraser is the preferred method for cleaning the slip rings.
              That's the lesson for today. CZ
              • jwhughes3
                • 2798
                • Home of the Alamo
                Thanks Cap
                Once again your years of "experience" will save me from making a mistake down the road.
                Glad you are here.
                John
                '81 XS1100H - "Enterprise"
                • dpotter58
                  • Aug 2004
                  • 1853
                  • Southern Maryland
                  How long did it take you to find the plug??? Mine took at least 2 days
                  1980 LG
                  1981 LH
                  • XJfan1
                    • Feb 2012
                    • 180
                    i found after about ten minutes. nothing to bad i guess
                    1982 xj 1100
                    "The Ape"
                    • XJfan1
                      • Feb 2012
                      • 180
                      Howdy,
                      ok well... no thats not the reason im looking for a stator. sanding a slip ring does not ruin the stator. im looking for a stator because four or five of the loops of wire are loose and rubbing aginst eachother. all the insulating materials that seperate the wire and the steel stator frame are brittle and falling apart. i used sand 1500 grit sand paper very lightly for just a moment till the oil flew out then i stopped. im not going to hand sand the slip ring copper is soft and would be easily ruined spinning it and lightly touching it i dont see a problem with. should i have continuity between the inner and outer slip ring? if i put a leed on each ring i get nothing.
                      1982 xj 1100
                      "The Ape"
                        • 8032
                        What do you mean by nothing? If you read zero ohms, the rotor is shorted. If you read infinity, the rotor is open, also no good. I'm not familiar with the XJ, but I think you should be looking for something like 5 ohms.
                        These folks can help: www.customrewind.com
