The MNS is to slow i think!
    • 8074
    Originally posted by mjpxs11sh
    my 81SH is a little shaky at 100. so i put 40psi in both tires, put 10psi in the front shocks and it seems better, but somethings causing a slight vibration at about 80, so i shut er down. maybe its the tire. i had replaced my old cupped tire and put this one on a while back. eveythings ok at anything under 80. ive read these bikes top end is somewhere around 123mph? i couldnt think of goin that fast on this bike
    Something is wrong with your bike. If it were mine, I'd be after a fix in short order. The XS1100 Special is very stable at high speed, even beyond "the ton".
    • mack
      • 2411
      • Ontario, Canada
      vibration
      You'll need to be more specific with the vibration. Is it only at speed or is it tach (rpm) related. I had a slight vibration in the sf until I reshimmed it.
      mack
      79 XS 1100 SF Special
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      https://youtu.be/wB5Jfbp6SUc
      https://youtu.be/RaI3WYHSuWA
      Frankford, Ont, Canada
      613-398-6186
      • Danny Crawdad
        • May 2011
        • 239
        • Birmingham, Alabama
        Yeah, I'd get that fixed. My 81SH will cruise happily and stably at 100mph and beyond all day long. On a controlled course, obviously.
        XS11SH :: K&N Pods, 4->1, Dynojet kit, Barnett clutch springs, TC's fuse block, ATGATT
        Well, goodness. Look what we've got here.
        • planedick
          • Mar 2005
          • 2068
          • Yorba Linda, California
          #34
          Ton
          Seen 140 on mine and the thing that impressed me was the stability, like solid and didin't seem like 140 at all. A quick look at the speedo though got my yellow streak wide enough to drop the throttle some.
          Drilled airbox
          Tkat fork brace
          Hardly mufflers
          late model carbs
          Newer style fuses
          Oil pressure guage
          Custom security system
          Stainless braid brake lines
          • ddragon63
            • Jan 2012
            • 1101
            • Ridgefield, WA
            #35
            It's hard to hear the radio clearly above 90... So I don't crest that. ok well every once in a while I will. But not often. I'm never in a big hurry when I get on my XS... We will get there when we get there.
            Those of you that like riding 3 bills or better should try a modern sport bike or sport touring bike. 100 on a rocket feels like 60 on a cruiser.
            Btw the speedo reads false @ the top end boys.... I've tested mine against my gps. But most all speedos read false after about 75.
            Don
            old:
            1989 kawi ex500
            1996 yzf-r6
            1999 yzf-r1
            2001 kawi zx-6r
            2000 Ducati 748
            2002 YZF-R1
            2005 V-Star 1100 Classic
              • 8074
              I replaced my tires and my tach. Just recently I was noticing how much higher the tach reads at a given speed than the old one did. Then it occurred to me, my front tire is running closer to the fender than it used to. The Metzelar tire I put on is noticeably larger than the Dunlop I took off. 100/90-19 for both.
              • planedick
                • Mar 2005
                • 2068
                #37
                Speedo
                I think all the XS speedo's are 5 MPH fast. Ever one I have seen so far is. I think the Japanese think they might save us some speeding tickets by doing that. We have lots of speed control signs around here that measure you speed as you go by and post it there for you to see and always I'm 5 mph fast. I tested mine with the GPS at 85 and it was 5 mph fast there also. I haven't checked at higher speeds 'cause I don't wanna take my eyes off the road at 3 digits.
                Drilled airbox
                Tkat fork brace
                Hardly mufflers
                late model carbs
                Newer style fuses
                Oil pressure guage
                  • 8074
                  Isn't the 100/90-19 a little smaller than the original non metric size?
                  • cywelchjr
                    XS-XJ Super Guru(Deceased)
                    • 4450
                    • Sacramento, CA
                    #39
                    The front was always metric, it was only the rear on the standard that wasn't originally metric. The manual specifies the 110/90 19 as the standard size, however the same marked size tire will be a bit different from manufacture to manufacture.
                      ALL Honda speedos are 5mph fast just cause of the liability factor. My XS Venturer is dead-on through all speed ranges verified GPS.
                        Beg to differ with ya there Cy, the front tire was originally a 3.50H19, rear 4.50H17. Verifiable in my original yellow owners manual........and I put enough of them on this scoot back in the day to know that was correct....BTW, GPS'ed 123mph is just as stable as it was 30yrs. ago..........and close to about it with fairing and all three trunks. Tach has a bit more left, but these scoots ain't got the HP to overcome mother nature fully dressed up..........
                        • cywelchjr
                          • 4450
                          • Sacramento, CA
                          #42
                          You're right, I just looked at the manual and it's not metric on the front, which I thought I remembered it being, only the rear for the special was. I guess the metric version is just very close, cause my speedometer is right on.
                          • T99Ford
                            • 678
                            • Bozeman,MT
                            #43
                            Agreed. 120-125 is near top end on the 1100. The speedo is not fixed at one constant "overage". It gets increasingly less accurate the faster you go. I did verify that one, one day, and was really disappointed to find out what my top speed really was.
                            All I have to say is to ride the 11 for what it is. It is a very reliable nod to the early high performance days, has a great pedigree, and is a ton of fun in its own right. But its not a rocket, and can't easily be made into one. Those are the rules of physics, not mine.
                            Healthy is merely the slowest rate at which you can die
                            Some people will tell you that slow is good - and it may be, on some days - but I am here to tell you that fast is better. I’ve always believed this, in spite of the trouble it’s caused me. Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba….Hunter S. Thompson
                            • jjz28
                              • Apr 2012
                              • 1023
                              • Beckley, W. Va.
                              #44
                              It feels like a rocket compared to my xs750.lol I love these bikes, i think they have PLENTY of power. If you need more then you have the wrong kind of bike anyway.
                              77 XS750 2D completely stock
                                Actually, owners manual shows 4.50H x16 for BOTH Standard and Special.....
