Like Mr Madmax-im, I know a bunch of people that have gone to car tires. Some skeptically, some not. And these people are experienced, aggressive, high mile riders. I don't recall hearing anything but good.
Another tire choice? Not what you think...
If it were a $100 less I'd be sorely tempted....Fast, Cheap, Reliable... Pick any two
road fix inconvienience
If you should need to replace car tire on bike, plan on removing wheel yourself and taking it to the car tire dealer. Could be extra trouble, especially while traveling.It is a great big beautiful world out there
Brent in GA
Yamaha 80XS1100SG, HD Firefighter Special Edition 02 Road King, Honda 450 rat, 08 Buell 1125R tour modified, 83 goldwing parts bike gone-traded for XJ1100, 2014 HD electraglide policeComment
Definitely true Brent. Likely be mounting it yourself as I doubt any commercial tire shop whether bike or car will touch it. Besides, this would NOT be a good option with the XS wheel as it is NOT quite wide enough to give propper sidewall support. In fact, it apparently is not a good choice on our early ST's as the wheel doesn't have the width that the 96 and later ST's do. Something to consider for safety reasons.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Quick Change Rear Tire Change GL18
Here's how some guys change out the rear tire
without having to remove the center rear fender section
Only 5 lug nuts and off it comes to swap the new one on.
I still do it the ole fashion way on the main stand...
Current Rides:
02 GL1800 Wing
79 XS1100SF Sold 10-15-12
81 XS1100H Venturer Sold 10-27-12Comment
Seems like there would be gas and oil leaking out everywhere.Greg
Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid.โ
โ Albert Einstein
The list changes.Comment
Gas tank is closed loop f.i. system. As long as you only lay it over to get the wheel off and on, not enough time to get oil coming out of it...Now if you lay it over and then scratch your head a while, have a couple of cold ones, go take a nap, eat lunch, and take alot longer than necessary, it might become a problem.But, if you have your break-over bar and torque wrench all ready to go, it doesn't take long to remove the 5 lug nuts, swap the wheels & tires and button it up and re-torque the lugs and set the bike back upright. As I mentioned, I still do it the ole fashion way as I have to take my time doing anything I do and I can't get in a rush. There's a large following of these guys who swear by this method and no one has ever mentioned leaking fluids involved in the process.
Current Rides:
02 GL1800 Wing
Any bike without a centerstand would get laid over for a road flat. I have done it and seen others do it on KLR's and hardtail harleys.Trapped in time. Surrounded by evil. Low on gas.
1980 XS1100G 1179 kit, Tkat brace, progressive springs & shocks, jardine spaghetti, Mikes coils, Geezer's rectifierComment
No vents in any of the drives or engine?
โ Albert Einstein
Six bikes ago I bought a brand new 2007 Suzuki M109R. I thought it looked "cool" and it was a very large cruiser, weighing over 700 lbs. It was one of the first bikes I ever saw that rolled off the assembly line with a 240 rear tire. It was wide, and flat as a pancake. It wasn't a car tire but it sure looked like it was one. From the first ride to the last (when it was on it's way to be traded after only about 6 months) it handled like it was a tank. It rurned very slowly and when you got to the edge, it dropped like a rock and wanted to "fall" into turns. I decided it was just plain dangerous and sold it at a huge loss but I just couldn't ride it because it made me lose confidence in the performance of the bike. I've had every style of bike from Harley touring rigs like the Electraglide to outright sport bikes like my FZ1 and every damned one, except the 109R has had rounded tires and was pretty easy to lean and point and shoot except the 109R which was like a dog that had it's own intensons. I can appreciate every rider wanting to try, and use, whatever he/she wants, but my life depends on my ability to maneuver quickly and accurately and I just don't believe a flat car tire on my bikes will do it as well as a rounded tire.Can't beat the smell of gas & oilComment
It sounds like the problem with that Suzuki was a bike problem, not the tire...
The one constant that is reported by the riders making the switch to car tires is the bike won't 'fall' into a corner; the effect is just the opposite. When turning, the rider has to 'make' the 'set' into the corner and maintain it as the bikes tendancy will be to want to pop back up straight. From everything I've seen/read, this isn't a big deal, just something the rider has to get used to.
I'd like to try this, but unfortunately for all XS owners (and my Sportsters too) the only equivilent size car tire (5.50 x 16) is one that was last commonly used in the 1940s, so the only choices out there any more are from 'vintage' tire suppliers at inflated prices and most with same-vintage technology...Fast, Cheap, Reliable... Pick any two
Better mileage
I used to run those Dunlops, but only got about 2500 miles on them. I tried the Michelin and get better than 5000 miles on those. You should try 'em TC.You can't stay young forever, but you can be immature for the rest of your life...
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
Custom security system
Stainless braid brake linesComment
