anybody use low voc paint?
  • GARTHXS
    • Nov 2007
    • 1631
    • Seattle
    I'm gonna paint my bike and I want to use low voc paint any tips and anybody have a good source for a kit ?
    91 kwaka kz1000p
    Stock
    ( Insert clever quote here )
    Garth, prep work is the key.
    Get a box disposable vinyl gloves so you won't touch any cleaned surface with your bare hands.
    Clean off the silicone, wax, and grease before you start.
    If the prep work is done right you can make pizza sauce stick and look good!
      Hey Garth,
      Are you meaning Low Velocity ?? My B-I-L just told me that it's water based!
      I used an HVLP sprayer IIRC when I painted my bike, just a simple HF sprayer, and some modest priced 2 part paint/clear from PPG, I think it ran about $100.00 total for both paint and clear/hardener and such.
      I had to get a respirator type mask, the fumes are quite toxic and harmful. Set up a paintbooth in my garage with sheets of plastic drop hung on ropes and such!
      • GARTHXS
        • Nov 2007
        • 1631
        • Seattle
        Voc volitile organic chemical
        91 kwaka kz1000p
        Stock
          Hi Garth,
          the trick would be finding a source of real paint.
          Seems the paint stores are limited to selling tree-hugger paint these days so that's what you will be stuck with using.
          Let us know how well the stuff works for you.
          I'm sure that I'm not the only one who has used up his stash of the good stuff.
          • GARTHXS
            • Nov 2007
            • 1631
            • Seattle
            I plan on using my g tank for practice and then I will try it out on my h tank . It just a matter of getting all The odds and ends together with my budget . Any tips on how much prep supplies?
            91 kwaka kz1000p
            Stock
            • scoot
              • Dec 2007
              • 153
              • Poway, CA: San Diego County
              local source
              Garth, TCP Global has a good website, they sell on ebay, and they're right here in san diego with a storefront. I'm painting my bro-in-law's goldwing this sat/ sun, but using high V.O.C. poison-vapor paint. Don't know about the low voc stuff yet, but you should be able to find it easy, all the paints are changing over. Side note, just paid $20 for 1 gallon of laquer thinner yesterday at home depot.
              scoot
              • GARTHXS
                • Nov 2007
                • 1631
                • Seattle
                Thanx scoot I will check it out . And a side note we need to get the SD crew together for.some seat time
                91 kwaka kz1000p
                Stock
                • scoot
                  • Dec 2007
                  • 153
                  low voc paint in S.D.
                  Garthxs, got another local source, Kearney Mesa Auto Paint off Convoy @ Kearney Mesa. Went there today to meet Bro- in law to pick out his paint and sundries. I like them better than TCP Global. They were real eager to set us up with the right stuff. And they do all low voc paints. Mix up the base color right there in 5 minutes. But be advised, my bro paid just under $400 for everything. Although we needed about twice as much stuff to do a 'wing compared to a (almost) naked xs.
                  I'm up for riding any weekend, just let me know.
                  scoot
                  • GARTHXS
                    • Nov 2007
                    • 1631
                    • Seattle
                    I'll check it out pm me your number and maybe we can go for a ride sometime
                    91 kwaka kz1000p
                    Stock
                    • scoot
                      • Dec 2007
                      • 153
                      Garthxs, pm sent
                      • GARTHXS
                        • Nov 2007
                        • 1631
                        • Seattle
                        So what did you get for 400 bucks scoot?
                        91 kwaka kz1000p
                        Stock
                        • scoot
                          • Dec 2007
                          • 153
                          Garthxs, here's the breakdown:
                          1.5 qt dark gray metallic base coat $152.24 ($100/qt)
                          slow reducer 2 qts. $31.00
                          clearcoat 2 qts. $65.08
                          hardener 1pint $36.40
                          acetone 1 gallon $15.36
                          black primer 2- 15 oz. aerosol cans $24.00
                          sanding block $9.37
                          5 sheets P600 wet/dry sandpaper $5.40
                          tack cloth $1.50
                          1 sheet each, 320, 400, 1500, 2000- no charge
                          1 water separator for the gun, no charge
                          3 small mixing containers, no charge
                          2 large mixing containers, no charge
                          18 bamboo stir sticks, no charge
                          22 paint filters, no charge
                          tech sheets, no charge
                          helpful hottie at the counter, priceless (thanks, Paige)
                          Again, all this above is for a 1984 Goldwing, lots of parts to paint. Took 2 of us 5 hours today to disassemble the plastics and remove badges and latches.
                          Washing these parts took almost 2 hours. Tomorrow we'll sand, clean again, and maybe begin priming. L-o-o-ong process. Needs beer.
                          scoot
                          • GARTHXS
                            • Nov 2007
                            • 1631
                            • Seattle
                            I was gonna say that must be some expensive paint
                            91 kwaka kz1000p
                            Stock
