Hello New to site with a intake question
  • ddragon63
    • Jan 2012
    • 1101
    • Ridgefield, WA
    Thanks guys... Gives me some options.
    Don
    old:
    1989 kawi ex500
    1996 yzf-r6
    1999 yzf-r1
    2001 kawi zx-6r
    2000 Ducati 748
    2002 YZF-R1
    2005 V-Star 1100 Classic
      We've got some long trips planned for this summer and I dont wanna encounter a leaned out cyl due to a split boot I didn't care for in the middle of the high dessert of central washington... that would suck! ////////////// I have regularly used the thick good quality vacuum caps from NAPA and have found they get hard and crack/break within 3,000mi. An aughful lot of heat is transferred from those brass nipples. The OEM caps and spring clamps ARE still available from your local dealer as an option. There HAS been a couple of instances of 'holed piston syndrome' due to a vacuum cap other than OEM failure. A carb boot failure while riding is highly unlikely and should of been addressed LONG before that would happen.
      • ddragon63
        • Jan 2012
        • 1101
        • Ridgefield, WA
        Motoman thanks for the heads up. I think George fix and a couple other internet companies carry the stock replacement ones too. I'd set fire to my local yamaha dealership before I'd step inside of it... But there a couple other ones across the bridge in Oregon I can try I guess.... The only vac caps I've ever seen hold up over the years are ones I've bought from truck stops. So maybe ill chase some factory yamaha replacements down. Better safe then sorry.
        Don
        old:
        1989 kawi ex500
        1996 yzf-r6
        1999 yzf-r1
        2001 kawi zx-6r
        2000 Ducati 748
        2002 YZF-R1
        • XS1100_OEM4ME
          • Mar 2009
          • 1619
          • Fort Myers, Florida
          +1, and you can get the plastidip in a spray can and make them look and work like new for just a few $$$$
          Before you spend the money, make sure yours are cracked badly enough to need replacing. They can have pretty nasty-looking cracks on the outside but have none of them go through the boot. You can 'paint' those with 'plastidip' (the stuff for tool handles) to seal/renew them and they can work just fine...
          1980 XS1100 Special
          1990 V Max
          1982 KZ750 LTD Twin
          1974 CB750-Four
          Past/pres Car's
          • ddragon63
            • Jan 2012
            • 1101
            • Ridgefield, WA
            That'll be my first step
            Don
            old:
            1989 kawi ex500
            1996 yzf-r6
            1999 yzf-r1
            2001 kawi zx-6r
            2000 Ducati 748
            2002 YZF-R1
            • ddragon63
              • Jan 2012
              • 1101
              • Ridgefield, WA
              Well I got bored...
              Pull the cover off the "Old man" and fired it up to check intake leaks. let it warm up and hit them with both seafoam and starting fluid. No change in idle. but if you push on #1 and #4 it feels like your finger could break thru @ any time. Lil brittle
              Willing to bet they are the stock onesfrom 79... probably oughta just bite the bullet and buy new ones.
              Don
              old:
              1989 kawi ex500
              1996 yzf-r6
              1999 yzf-r1
              2001 kawi zx-6r
              2000 Ducati 748
              2002 YZF-R1
                There are three layers in those intake boots. Inner rubber, brass sleeve with the mounting base, and the the outer rubber. The brass goes about 2/3 of the way to the carbs and then it is just rubber so that you have the flexibility to get the in.
                • ddragon63
                  • Jan 2012
                  • 1101
                  • Ridgefield, WA
                  So... what your telling me is not to worry about it? heres a picture of one. disregard the lint from a red shop rag on it LOL
                  man you don't realize how dirt something is till you take a close up with an HD camera... embarrassing.....
                  Don
                  old:
                  1989 kawi ex500
                  1996 yzf-r6
                  1999 yzf-r1
                  2001 kawi zx-6r
                  2000 Ducati 748
                  2002 YZF-R1
                  • GLoweVA
                    • Jun 2011
                    • 1957
                    • Virginia Beach, VA.
                    The outside of those look better than the ones I have on my 80G (83K miles)
                    I'd agree with the others and say if they're okay on the inside and there's no change with the seafoam spray then you've got no leaks.
                    The PlastiDip might make them look a little better.
                    New ones look nice but being new, the rubber is tougher/tighter and it'll be a PIA to get the carbs on and off until they get 'broken' in a little.
                    But hey, for $65 you can't beat that kind of insurance.
                    80G (Green paint(PO idea))
                    The Green Monster
                    Got him in '04.
                    bald tire & borrowing parts
                    Scarlet
                    Got her in '11
                    Ready for the twisties!
                    81H (previously CPMaynard's)
                    Hugo
                    Cold weather ride
                      Shoot, those boots look pretty decent. I'd use those in a heartbeat...
                      • ddragon63
                        • Jan 2012
                        • 1101
                        • Ridgefield, WA
                        I hoses em down real good inside and out with no ups or downs in idle. Guess we'll leave em be. 1 less thing to do before spring. Thanks guys
                        Don
                        old:
                        1989 kawi ex500
                        1996 yzf-r6
                        1999 yzf-r1
                        2001 kawi zx-6r
                        2000 Ducati 748
                        2002 YZF-R1
                        • Yahman
                          • Mar 2008
                          • 779
                          • Salem, OR
                          I have a set of these and have not had any problems with them, they appear to be of good quality.
                          Larry
                          82 XJ1100
                          80 XS1100G (Project bike)
                          64 Yamaha YA-6
                          77 Suzuki TS-185
                          • ddragon63
                            • Jan 2012
                            • 1101
                            • Ridgefield, WA
                            Thanks Larry.
                            Don
                            old:
                            1989 kawi ex500
                            1996 yzf-r6
                            1999 yzf-r1
                            2001 kawi zx-6r
                            2000 Ducati 748
                            2002 YZF-R1
                              • 7949
                              I recently replaced mine. I bought them from Parts-N-More. My old ones looked very good. I couldn't see cracks. Just the same, there was evidence of leaking. You just never know.
                              A tip: I use vinyl/rubber dressing to lube the boots for carb installation. It works the charm. Armor All will do the same thing.
                              • ddragon63
                                • Jan 2012
                                • 1101
                                • Ridgefield, WA
                                Thats a good tip Marty!
                                I sprayed the crap out of my boots with seafoam, and then starting fluid and the idle never changed a beat. I think I'll keep these on there for another summer. I'll keep an eye on them and check them from time to time. the cracks seem to be more stress from holding the weight of the carbs all these years more than weather checking
                                Don
                                old:
                                1989 kawi ex500
                                1996 yzf-r6
                                1999 yzf-r1
                                2001 kawi zx-6r
                                2000 Ducati 748
                                2002 YZF-R1
