Hello New to site with a intake question
  • ddragon63
    • Jan 2012
    • 1101
    • Ridgefield, WA
    hello all,
    Has anyone got any experience with the carb holders that are being sold on ebay for $70 to $90 a set. seem good priced but I always get leery about under priced stuff on "flea"bay. Especially for motorcycles. I got some cracked ones that need to be changed out. Thanks in advance
    Don
    old:
    1989 kawi ex500
    1996 yzf-r6
    1999 yzf-r1
    2001 kawi zx-6r
    2000 Ducati 748
    2002 YZF-R1
    2005 V-Star 1100 Classic
    • 3193
    Georgefix on ebay is a very good person to deal with and he is very competitive with any others. I buyt mine from him as well as many other parts such as brake rebiuld and carb kits. I think you will find he has a very high "Rep" on this site.
    • mack
      • 2411
      • Ontario, Canada
      George fix
      I've had nothing but positive experiences with George fix. Make sure you get new nipples with the boots. The old ones get brittle and can leak. Bit of drag hooking up the vacumn stick and tuning the bike to perfection, only to put the old nipples back on and have it run like sh.t, then stand there scratching your head.
      mack
      79 XS 1100 SF Special
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      https://youtu.be/wB5Jfbp6SUc
      https://youtu.be/RaI3WYHSuWA
      Frankford, Ont, Canada
      613-398-6186
        Before you spend the money, make sure yours are cracked badly enough to need replacing. They can have pretty nasty-looking cracks on the outside but have none of them go through the boot. You can 'paint' those with 'plastidip' (the stuff for tool handles) to seal/renew them and they can work just fine...
        • old_skool
          • Nov 2011
          • 554
          • Ohio
          what about replacement gaskets once you remove them?
          81 XS1100H
            • 8904
            Ford 2.3L thermostat housing gaskets are a very close fit, minimal trimming.
            • old_skool
              • Nov 2011
              • 554
              • Ohio
              AWESOME!!!
              81 XS1100H
              • ddragon63
                • Jan 2012
                • 1101
                • Ridgefield, WA
                thanks guys... I've been reading that they're double layered and can look that crap and still not be cracked all the way thru. I'll get the seafoam out and spray them down and see if they leak. I would assume some hi temp gas resistant silicone could replace gasket? I've seen the intakes with gaskets for around 80 bucks on ebay. As far as the plugs most any high quality carb vac cap should work I would think?
                George Fix is the man! we just got done emailing back and forth for the last week making sure I get the right petcock rebuild kits. Turns out my old man must have put a standard tank on this SF bike back in the day... after many emails and digging around the bike I figured it out. I will just assume he changed the tank for more fuel. once I looked up picture of other bikes the visual differences are plain to see.
                Don
                old:
                1989 kawi ex500
                1996 yzf-r6
                1999 yzf-r1
                2001 kawi zx-6r
                2000 Ducati 748
                2002 YZF-R1
                • ddragon63
                  • Jan 2012
                  • 1101
                  • Ridgefield, WA
                  BTW the bike runs fine... We've got some long trips planned for this summer and I dont wanna encounter a leaned out cyl due to a split boot I didn't care for in the middle of the high dessert of central washington... that would suck!
                  Don
                  old:
                  1989 kawi ex500
                  1996 yzf-r6
                  1999 yzf-r1
                  2001 kawi zx-6r
                  2000 Ducati 748
                  2002 YZF-R1
                    Easy way to tell the tanks apart is, standard tank is big and square with knee indents and a recessed gas filler door in the top center. As well as big fat vacuum operated petcocks.
                    Special tank is a teardrop style tank with an offset non recessed gas fill door. With small petcocks that are not vacuum operated (but would have a separate vacuum operated cutoff).
                      • 8064
                      intake manifolds
                      Four new ones for $65.
                      • ddragon63
                        • Jan 2012
                        • 1101
                        • Ridgefield, WA
                        ya its a standard tank. Serial number on the bike is for an sf but its a big square tank
                        Don
                        old:
                        1989 kawi ex500
                        1996 yzf-r6
                        1999 yzf-r1
                        2001 kawi zx-6r
                        2000 Ducati 748
                        2002 YZF-R1
                        • GLoweVA
                          • Jun 2011
                          • 1957
                          • Virginia Beach, VA.
                          WOW Marty, those are NEW for only $65! That's a steal.
                          80G (Green paint(PO idea))
                          The Green Monster
                          Got him in '04.
                          bald tire & borrowing parts
                          Scarlet
                          Got her in '11
                          Ready for the twisties!
                          81H (previously CPMaynard's)
                          Hugo
                          Cold weather ride
                          • ddragon63
                            • Jan 2012
                            • 1101
                            • Ridgefield, WA
                            ya for that price a fella could just buy some and not worry about cleaning and painting his.... i just know georgefix sells em for over $100... so my question is are they same quality?
                            Don
                            old:
                            1989 kawi ex500
                            1996 yzf-r6
                            1999 yzf-r1
                            2001 kawi zx-6r
                            2000 Ducati 748
                            2002 YZF-R1
                              • 8064
                              I bought my carb holders from Parts-N-More, so I can't vouch for these. What I did buy from Sirius was first rate quality, so I wouldn't hesitate. Also, my bike was down last time I purchased and the shipped immediately. So, my experience was good all around.
