server not found
  • DeanR
    • Jan 2005
    • 1486
    • Finger Lakes NY
    server not found
    I've been getting this message a lot recently. 'Server not found'. Anyone else? Have only noticed it here at XS11.
    80 SG
    81 SH in parts
    99 ST1100
    91 ST1100
  • jwhughes3
    • 2798
    • Home of the Alamo
    Me too
    After I wait awhile I get in.
    Weird.
    John
    '81 XS1100H - "Enterprise"
      Yeah, the site crashes pretty regularly for me too. The only time it really irritates me is when I'm posting and I lose the post....
      • latexeses
        • Jun 2008
        • 1491
        • California
        When it happens to me I punch up a saved link and I get right in.
        Everything on hold...
          Hasn't been an issue here............don't know whether Wi-Fi makes any difference.
          • patk12345
            • 96
            • Chicago, IL
            I have it happen quite often, glad to hear I'm not the only one.
            Pat K
            80 XS11 "Special" Standard
            (80G chassis & engine w/ 79 SG lights and cluster)
            79 XS650 (engine currently squeals like a stuck pig.)
            72 Plymouth Satellite (met an unpaved manhole collar, which it managed to tear out of the street, currently has some "issues")
            04 Current Designs Solstice GT XL Kayak (I like it because it doesn't have carbs, or any other moving parts)
              Hi Dean,
              Which part of We are ignoring you... are you having trouble with
              I have had that a few times too always on wi-fi.
              Are you coming to the Toronto show?
              • petejw
                • 2269
                • sydney australia
                happing over here too.
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                1981 xs1100 RH (aus) (5N5)
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
                • cywelchjr
                  XS-XJ Super Guru(Deceased)
                  • 4450
                  • Sacramento, CA
                  It's almost always a DNS server failure at the hosting facility where the site is hosted. The almost 100% cure is to add the following line to your hosts file (for windows users)
                  64.119.182.118 www.xs11.com
                  you hosts file is normally contained in C:\WINDOWS\System32\drivers\etc and the filename is just hosts with no extension but you can edit it with notepad.
                  Since doing that, I have found that I almost never have this type of problem with the site anymore, where I used to have it fairly often. I believe in giving credit where credit is due, and IIRC it was 3phase who clued me in to using that technique to get around the problem with the site.
                  PS, you MIGHT have to change the rights on the folder in newer version of windows such as Vista or Windows 7 to give users edit rights to be able to do this.
                  • xs11jack
                    HALF GURU
                    • Nov 2002
                    • 606
                    • O'Fallon, Mo.
                    Don't have a bit of trouble. Must be because I am a PACKER fan.
                    Ole Jack
                    J.D."Jack" Smith
                    1980G&S "Halfbreed"
                    1978E straight job
                    "We the people are the rightful masters of both congress and the courts, not to overthrow the constitution, but to overthrow the men who pervert the constitution." Abraham Lincoln
                    Life is like a coin, you can choose to spend it any way you wish, but you can only spend it once. Make your choices wisely.
