I got myself a xs11 special (1980) not long ago and I was just changing the oil filter. When I finished I noticed I had fogotten a spring. I don't remember if the spring was above the filter or below so I put it above but on looking in the manual (after finishing) it appears it might have been below. My question is does it really matter if the spring is above or below? I just don't want to go buy more oil and take it back apart if I don't have to.
Oil Filter Question
I got one at the dealer, in stock and only like $1.00 or something.Gary Granger
Does anyone have the specs on the following parts? I need to goto home depot or something and try to buy replacements. After the oil change there seems to be a slight oil seepage from both the bolt under the filter and the drain bolt.
1) Oil filter cover O ring
2) Washer for under the oil filter (btw does this go above or below the spring)
3) gaskets for the drain bolt.
I can't see the actual specs on these parts in my manual.
The o-ring comes with the NAPA or Fram filters, not sure what size, cant you take the cover with you to get one? Or buy a NAPA or Fram and use the 0-ring twice?
The oil filler bolt washer is actually a crush ring, you will need to go to a auto parts store with the bolt and get a 'crush washer' of the same size. These are the same washers you use inbetween the brake hose fittings only bigger. They are available in aluminum or in copper, either will work.
The washer for the filter is special (very thin and mut be the right diameter both in and out) and I would go to the dealer and pony up my dollar and get the right part. Mine was 85 cents at Zannotti's Yamaha.
So you need less than $3 in parts here.Gary Granger
