Tach/Dwell Meter
  • MrOzz
    • Aug 2008
    • 782
    • Massachusetts
    Tach/Dwell Meter
    I am looking for a tack/dwell meter.
    Seeing what you guys use and if you have and recommendations.
    Thanks all,
    Ozz
    1980 XS 1100SG
    Dyna 3 Ohm Hi Output Coils
    Pod Filters
    DynoJet Kit
    T.C.'s Fuse Block
    V-Max Auto CCT
    Any automotive type will work, it's just a matter of whether it will give an accurate reading or if you will have to do math. Most of them you will have to do math with, and since points are LONG gone now, they are getting hard to find, mostly they only are good to check the idle speed, and there are other devices to do it with. One that I have on my wish list is one from Harbor Freight that you press against the rotating assy and tells you the RPM. They have another that you can just point it at it and get the same thing, I guess it's supposed to watch for something unique that it sees on the rotating assy to get the RPMs.
      I found a tach that is used for rc airplanes/helicopters for $13 haven't got it yet still in transit. Put a price of tape across the timing plate and point it at it.
        Old Analog Meter?
        Ozz,
        I own and use the tach/dwell meter near the end of this video:
        You can see it's just an old analog meter. I got it at a garage sale for $5.00.
        I use it for all my vehicles and not just for the bike.
        • DAVINCI
          • Jan 2011
          • 1048
          • Cedar Mountain, NC
          Can't beat old school..I use my dad's old SUN.
          • MrOzz
            • Aug 2008
            • 782
            • Massachusetts
            Pardon my ignorance, But you can get the proper engine RPM by using a digital no contact laser photo tachometer by pointing it at the timing plate?
            1980 XS 1100SG
            Pod Filters
            DynoJet Kit
            T.C.'s Fuse Block
            V-Max Auto CCT
              It is connected to the end of the crank shaft so that would give a perfect rpm.
              • MrOzz
                • Aug 2008
                • 782
                • Massachusetts
                That makes perfect sense.
                Thanks!
                1980 XS 1100SG
                Pod Filters
                DynoJet Kit
                T.C.'s Fuse Block
                V-Max Auto CCT
