Carb Diaphragms
  • Aches n Pains
    • 349
    • Reston, Va.
    Carb Diaphragms
    I'm working on three carb sets that were disassembled when I bought them. Everything is in good shape but the diaphragms (as most rubber) have "shrunk" a little making them hard to set into the channel under the carb cap.
    Anyone have any ideas on how to "stretch" the diaphragms or put some material in the channel that will hold the diaphragm in place. They are in good shape just a little out of shape at the top.
    Thanks,
    Aches n Pains (Doug)
    1995 KZ100P
    Pods, jets, pipes, cam adjuster, oil cooler
    1977 Ironhead - custom build
    Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
    Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
    Doug,
    I have had decent success with this by just pulling them lightly and then pushing them into the channel and using a thin very rounded edged metal spatula to hold them down while I got the top in place then gently pull the metal out while holding down with the top. It takes several trys, but eventually get there.
      • 8878
      I've heard of a feeler guage(s) being used to hold the diaphram down, then slip it/them out with the cap in place.
      • latexeses
        • Jun 2008
        • 1491
        • California
        +1
        Had SWMBO hold the gauges. Used two. Made it a ton easier.
        Everything on hold...
          Rub and stretch gently with silicone and then put some vaseline in the groove to help the diaphragm stick in the groove as you put the cover on.
          • Aches n Pains
            • 349
            • Reston, Va.
            Thanks to all who responded. Will try a little Vaseline and some feeler gauges.
            Doug
            1995 KZ100P
            • WMarshy
              • Apr 2009
              • 2402
              • Mexico NY
              Doug
              Sounds a little too personal.
              '79 XS11 F
              Stock except K&N
              '79 XS11 SF
              Stock, no title.
              '84 Chevy K-10 "Big Blue"
                • 8878
                Thats funny, LMAO. <spit>
                • foreda
                  • 949
                  • Southwest Louisiana
                  Diaphragms
                  Here is a source in case you fubarb one.
                  78 XS1100E Standard
                  Coca Cola Red
                  Hooker Headers
                  1979 XS1100 Special
                  1980 XS Standard
                  2006 Roadstar Warrior
                  • 81xsproject
                    • 3185
                    • Fortuna, CA
                    Spray them with spray silicon lube and get them nice and clean. Make sure they are not cold, and using all your fingers, work the diaphragm into the groove and just hold it there for a few minutes. The diaphragms will stretch back out and you should then be able to quickly get the cap on. This is all that you need to do. It happens on every set if the diaphragms are out for a while.
                    '81 XS1100 SH
                    Sep. 12th 2015
                    RIP
