Here's my concern about the running the engine to 10k to achieve this. I know these engines are stout, but remember, that bearings are becoming pretty much NLA at any price and rings are available ONLY in oversize and pistons are not, and while there IS a big bore kit, I understand they are running their LAST run of those, so parts are getting scarce, which means in the future, custom made parts (I believe there are places that will make almost any part to spec, but they can be REALLY costly), as this is how some of the restorers of really old stuff do it, and it's why it can be so costly, fabricating a full set of custom bearings, and a full set of custom pistons and having a full set of custom rings made (although I understand there are rings that would work if only the grooves were a tiny bit deeper which if you made custom pistons you could do). Engines are still around but they are going to get harder and harder to get in good condition.
This makes me nervous about abusing the engine too much, I consider redline a safe place, the engineers clearly felt it was a safe place to be able to run the engine up to, and I'm thinking even sustained runs up to there are ok as long as everything else is in good condition. But 10k? that's 1500 RPM over redline.
Maybe that's not a lot, but it could be the difference between and engine that does 200k and one that does 60k.
