Venturer Gas Tank on eBay...
    http://cgi.ebay.com/ebaymotors/1980-...item2c5cbe47e1
    Mis-identified as a '80 tank, but that's a Venturer tank all right. Big dent, but you could go in through the petcock holes to knock most of it out. Looks pretty clean inside.
    Just a FYI for those looking for one...
  • jwhughes3
    • 2798
    • Home of the Alamo
    option
    "Less than sane" Steve - (politically correct terminology)
    Wasn't the 24liter tank an option in 1980 and only offered as the Venturer package in 1981? Seems like I read that in a vintage magazine article somewhere (who can remember)...
    I agree that is a good deal for someone needing one as long as it doesn't get bid up!!
    Adding in a 79 Special that seems like a nice candidate in Indiana...
    http://cgi.ebay.com/ebaymotors/Yamah...item27bb0b7454
    John
    '81 XS1100H - "Enterprise"
    • benxs1100
      • 92
      • Somerset, Pa
      Actually sometimes with a dent like that you can put the air pressure to the tank and tap around the edges of the dent with a rubber mallet to pop it out.
      '79 XS11 Special
      MikeXS Pods
      Green Coils
        John
        Hey John, the speedo says 80 or 81, so milage is unknown on that one. All else does seem to point to 79 though. Worse part is its only 1-1/2 hours from me, in area I go through often for work!! D-I-V-O-R-C-E......= Another bike!!!!
          Added to my watch list. If the price stays right I may jump on this one. It will take some work to sort out, and the fill area is pretty rusty and it will need to be completely stripped and painted, but I'm up for that, and since I was thinking about slightly higher bars, that might work out ok. It would give me a tank to spend some quality time with to make really first class before it went on, and I could have two tanks, one for long range and one for town (although I'm not sure why).
          Maybe just a backup tank hanging on the wall.
            • 5067
            Oh yeah, I tried that once. It widened the spacing for the mountings, and other bad things. I don't recommend using air pressure this way! It about scared the pee out of me!!!
            • benxs1100
              • 92
              • Somerset, Pa
              That sounds like a bit to much air pressure lol. 35 psi in a tire works as the tire is rubber and has give. A solid gas tank though requires much much much less.
              '79 XS11 Special
              MikeXS Pods
              Green Coils
                5-10 psi usually does it.
                • latexeses
                  • Jun 2008
                  • 1491
                  • California
                  ......and I was hoping no one would notice......
                  Everything on hold...
                    never works out that way does it.
                      That means none of us will be able to afford it and someone else will come in and pay more than any of us can afford to pay for it.
                        Everyone will bid against one another and run the price up
                        • jwhughes3
                          • 2798
                          • Home of the Alamo
                          Blame it on...
                          "Less than sane" Steve... he posted it!
                          No good deed goes unpunished!
                          John
                            Hey, just tryin' to be helpful...
                            Maybe your guys should figure out a lottery to see who gets to bid on it....
                            • cowboybob998
                              • Mar 2009
                              • 371
                              • KC MO
                              air presure
                              little air presure and heat around the dent, just make sure there is no gas fumes in the tank or ya my have a bomb
                              1979 xs1100 f
                              142 main, 45 pilot, Jardeen crosover 4/2, no air box
                              floats @ 25.7
                              1979 xs1100 F
                              1978 gl 1000 goldwing
                              1981 gl 1100 goldwing
                              !986 venture royale 1300
                              Just an ol long haired country boy, come to town to spend some egg money
                              when ya get bucked off, get back on
