What to take????
  • planedick
    • Mar 2005
    • 2068
    • Yorba Linda, California
    What to take????
    When you're loading up for a 8,000 mi trip, what do you consider necessary with one of these 11's?
    I've got spare bulbs, fuses, tire plug and patch kit, pressure guage, compressor, spare clutch and throttle cable, flashlight, bag of spare nuts, bolts, cotter keys, tape, wire ends, tie wraps, my somewhat extensive tool kit, heavy duty plastic sheet, duct tape, fuel line and probably a few things I can't remember......
    Drilled airbox
    Tkat fork brace
    Hardly mufflers
    late model carbs
    Newer style fuses
    Oil pressure guage
    Custom security system
    Stainless braid brake lines
    Bailing wire?
    • hamjam
      • 1003
      • Toronto ontario Canada
      cell phone CAA or you guys AAA card and master card
      Seamus Ó hUrmholtaigh
      Niimi Moozhwaagan
      NOTICE: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been inconvenienced.
      Any connection between your reality and mine is purely coincidental.
      Member of "FOXS-11" (Former Owner of XS-11)
      and SOXS
      2008 Nomad "Deja Buick'
      • STEPPENWOLF
        • Jan 2007
        • 4188
        • CINCINNATI OH
        More than I ever carried. But if your advanced timing wires are in good shape and the rest of the bike is ready to roll..you be set.
        I take a pad lock and slip it thu the rear disc and roll it around so you don't see it,they tried to steal my bike in Galesburg IL one night,rolled it back a foot,lock hit and they dropped the bike,minor damage but I still have it.
        One other thing..a good warm rain suit.
        '80 XS1100 SG
        • jwhughes3
          • 2798
          • Home of the Alamo
          Co2
          Coud you replace the compressor with a handful of CO2 cartridges? 4 wouldnt weigh what the compressor does no matter how small. Those spark plug chuffers are light too though Ive never used one on a 4 cyl.
          Cash or credit card. Some way to contact this forum (smartphone or iPod Touch to find help)
          John
          '81 XS1100H - "Enterprise"
          • Eveready1100
            • 539
            I'd prefer the compressor, personally. It gives you unlimited air as opposed to the cylinders where you've got 4 shots at getting it right, then you're stuffed.
            Also, if it's a camping type trek, they're very handy for pumping up the airbed.
            Other than that, it sounds like you've got everything, bikewise, covered.
            Except maybe a 12v test light, and they're small
              Couple 2 or 3 oil filters unless U plan on hittin' them up at Napa's on the trip. Other than that, an attitude adjustment and your good to go!
              • dpotter58
                • Aug 2004
                • 1841
                • Southern Maryland
                When I met Tod and Ivan in Kentucky last year Tod had a spare piston and connecting rod. May have had an oil pump in the bag too. That and 2 gallons of kaluha
                1980 LG
                1981 LH
                • Jamie
                  • Aug 2010
                  • 182
                  • Norman, OK
                  OMG, Kahlua (or however the hell you spell it) is for pussies, guess that's why Tod had it in his bag huh? Kahlua, that's pitiful.
                  • dpotter58
                    • Aug 2004
                    • 1841
                    • Southern Maryland
                    I don't know Jamie. If you can drink it and keep it down you are a better man than me
                    1980 LG
                    1981 LH
                    • planedick
                      • Mar 2005
                      • 2068
                      Also have
                      Rain suit, cell phone, quality volt/ohm meter, good bankroll and credit cards too, Magellin GPS and a security system on the bike that only sets off my pager if anyone even so much as touches my bike. My trusty mini bat takes care of such foolhardies. Doing an oil change before leaving with filter and will do one on the east coast so don't need a filter as I only change it every other oil change. I do have a few nitrogen cylinders, but I've found it takes at least four to do the job and that's not really full. I prefer the compresser. As for roadside assistance, I'm an AMA member for many years and the free roadside assistance works. I have also made arrangements for a new tire in Ithaca, NY for the return trip as I only get around 4,000 miles per tire.
                      Drilled airbox
                      Tkat fork brace
                      Hardly mufflers
                      late model carbs
                      Newer style fuses
                      Oil pressure guage
                      • jwhughes3
                        • 2798
                        • Home of the Alamo
                        4000 miles per tire!
                        Maybe you need to be running 40 PSI
                        John
                          Can't run 40 PSI in a motorcycle tire, John, lest all that pressure force the oil out of the tires and ye shall die!
                          Planedick: spark plugs; clutch and brake levers; headlight bulb; tail/brake and signal bulbs; fully charged mobile phone battery in a waterproof bag along with a written (in pencil, not ink) list of phone numbers, addresses, motel reservation confirmation numbers, etc.
                          • jwhughes3
                            • 2798
                            • Home of the Alamo
                            I will remember to oil my tires before next trip!
                            Planedick - I second the extra lever - but check the clutch cable too - I had one break on me and had a bi#@! of a time trying to ride with a vise-grip clutch lever.
                            John
                            • cowboybob998
                              • Mar 2009
                              • 371
                              • KC MO
                              Oil in tires, do i need to check that, wheres the dip stick,
                              1979 xs1100 f
                              142 main, 45 pilot, Jardeen crosover 4/2, no air box
                              floats @ 25.7
                              1979 xs1100 F
                              1978 gl 1000 goldwing
                              1981 gl 1100 goldwing
                              !986 venture royale 1300
                              Just an ol long haired country boy, come to town to spend some egg money
                              when ya get bucked off, get back on
