whats it called?
  • lee_dutcher
    • Apr 2009
    • 822
    • mason city iowa
    whats it called?
    when u have jets larger in the 2 and 3 cyclinder and smaller ione in the 1 and 4? is it called jet laddering? im tring to find info on why and pros and cons on it...
    1980 gs1000g "stock"
    No pros or cons really............air cooled and inner two cyl. run a bit hotter causing them to run a bit leaner so couple steps richer feeding those two cyls. compensate some for that........ some set thier carbs up like that........ some don't.
      That was done on the later '80-up bikes because the factory jetting was pretty lean for emissions purposes and the motors ran a bit hotter. As motoman said, they increased the jets on the two inner cylinders to compensate for this. There's no real performance advantage...
        Having owned two 81 models now, and opened up more than a few carbs, I have yet to find any still jetted like that. And I have never done so myself. All the carbs I have worked on worked excellent on every bike to date.
        Like stated, it was a way to give added cooling to the inner cylinders due to the richer mix. None of my engines have ever shown a lean condition in the inner cylinders. HTH
          • 8929
          IIRC, Yamaha stopped doing this after a few years. They probably had good reason to.
          • SFerinTEXAS
            • Jun 2006
            • 877
            It actually started with the 79 specials. While the 137.5 jets were on all carbs, 2 & 3 had emulsion tubes with less side holes to effectively reduce the air mixture / increase the fuel to air ratio for inner cyl cooling. Later specials did this with larger jets in 2&3.
            The idea behind this was that the standards would see more cruising miles and the specials would see more boulevard miles. Basically proved to be pretty irrelevant .
            79SF
            XJ11
            78E
