An Interesting Thought
    Originally posted by cywelchjr
    Wasn't the stock tire for the special also a non-metric tire, which may have actually been taller than the modern 130/90-16 just as the original stocker was taller than the 130/90-17 is...
    These bikes came out just as they were transitioning from the 'old' inch system to the new metric sizes. If you look at the factory brochures from the day, they show the special as having the 130/90-16 as OEM with the '79 model. I'm not sure when the metric 17s came in, as the inch size was still being sold as a replacement after the XS was out of production. The one I have I got in '83 or '84...
      • 8663
      Got a chance to clock my tall final/tire combo. Reads 65 MPH at 3.4K, with a light 5 MPH tail wind.
        I think I've figured just what the difference was...
        A 130/90-16 tire is 25.16" in diameter (Dunlop 404 as per their website). I know there's variations between brands and even models in the same brands (the EliteII in the same size is 25.7"), but for comparison purposes I'm using this 'tire line' as Dunlop also offers a 130/90-17 in the 404, which is 25.97". So, figuring circumference on the 16", you come up with 79.05". Add 5% to that and now you have 83.0". Figure diameter, and that works out to 26.42" for a 4.50H size. A 'modern' 130/90-17 is only 81.6" in circumference, for about a 3% difference. So...
        4.50H-17 tire = 3.3:1 ratio; original XS standard.
        130/90-17 replacement = 3.4 ratio.
        130/90-16 'special' wheel = 3.47 ratio.
        I couldn't find a 130/70-17 in a Dunlop, but their closest size (140/70-17) is still smaller than a 16" tire by 1%, so that would put gearing down to to nearly 3.5:1. That's why your motor was buzzing....
        Also makes sense in comparing my new 160/80-16 to the old 4.50; as I've noted, even worn this tire is still slightly larger, and diameter spec on this size is 26.2". So even this is 1% small compared to original; I'll have an effective ratio of 3.33:1.
        • Crusty Snippets
          • Sep 2010
          • 428
          • Gabriola BC
          Rpm
          Got a chance to clock my tall final/tire combo. Reads 65 MPH at 3. K, with a light 5 MPH tail wind.
          I am around 3750 at 60mph indicated. My speedo in kilometers reads about 3km over actual, according to the speed radar signs we have on the highway.
          My big white numbers show kilometers and the smaller yellow numbers show MPH. My tach wanders after in gets warm and or the revs increase.
          But I seem to be turning a few more revs than you. I have not checked the rear tyre size.
          Your message quoted above may have been altered by a mistroke on my part.
          Please blame the Piper's Pale Ale on special at the local watering hole.
          Uncle Crusty ( wifi at Starbucks )
