Valve clearences
  • planedick
    • Mar 2005
    • 2068
    • Yorba Linda, California
    Valve clearences
    While I had the head off Pathfinder I was doing the valve adjustment thing. The closest manual was the Clymers so I opened it to check specifications. I thought it was for sure wrong because it said the intake side was to be 0.0004 - 0.0016 in or (0.0010 - 0.022 mm) and exhaust was 0.0010 - 0.022 in or (0.025 - 0.055 mm)
    Went for the Haynes and it said intake was 0.006 - 0.008 in or (0.16 - 0.20 mm) and exhaust was 0.008 - 0.010 in or (0.21 - 0.25 mm) I don't know where Clymers got those nuimbers, but they're obviously wrong....
    Drilled airbox
    Tkat fork brace
    Hardly mufflers
    late model carbs
    Newer style fuses
    Oil pressure guage
    Custom security system
    Stainless braid brake lines
    My clymer has the same numbers as your haynes.
    • planedick
      • Mar 2005
      • 2068
      My Clymers
      Chapter 4, page 56 my Clymers has an engine specifications page which gives the specifications I mentioned. Clymers manual M411, Yamaha XS1100 1978 - 1981
      Drilled airbox
      Tkat fork brace
      Hardly mufflers
      late model carbs
      Newer style fuses
      Oil pressure guage
        Yup, my Clymer's says the same thing as yours, planedick. It shows shows an extra zero in the specs on page 56. However, it does show the right amounts in the pad selection procedure on page 46.
          I guess mine is the same on that page, BUT turn back to page 44, there is where its going through the procedure and it has the other numbers.
          • cywelchjr
            XS-XJ Super Guru(Deceased)
            • 4450
            • Sacramento, CA
            Which is even more interesting since the specs are not the same for all 4 years, but are different between the early and late style head.
              Oh the plot thickens!
              • planedick
                • Mar 2005
                • 2068
                Proceedure
                Well, I don't need to follow the proceedure 'cause I've done it before and I really did know the correct clearences, but I just thought I would check to be sure as I really like to do it right the first time. If you compare the two other references you give on pages 44 and 46 you will see that they are different from each other as well.
                Drilled airbox
                Tkat fork brace
                Hardly mufflers
                late model carbs
                Newer style fuses
                Oil pressure guage
                  Yeah I guess I remember looking at the numbers on page 46 and thinking something was weird. But there is that not there that says the numbers are for example purposes only so I ignored any numbers on pare 46.
                    I wonder why there isnt a late part in the back of the clymer manual that says the clearances for the later model systems.
                      In my Clymers manual, there is chapter 12 which gives all the updated info for the 80-81 model years.
                        Yeah mine has that too but I glanced through it quick and didnt see anything about different valve clearances.
                          On mine at least it is in there. You have ot find the section on valve adjustment. Chapter 12 is not subdivided into the 11 other sections per say. More than one section may even be on the same page. But if you find the valve clearnace check procedure part, it clarifies the smaller inlet valve clearance on the later models.
                            may bad, I looked in the engine section and not in the periodic maintenance section.
