car battery issue
  • GARTHXS
    • 1631
    • Seattle
    car battery issue
    So my car battery is a little low and I am charging it the green charged light goes on my charger then it goes back to charging Wtf is it done yet
    91 kwaka kz1000p
    Stock
    ( Insert clever quote here )
  • SFerinTEXAS
    • Jun 2006
    • 877
    Outta take to parts house and load test it. Know your winters aren't as hard as most others but that's the time of year an iffy battery likes to say adios.
    79SF
    XJ11
    78E
    • XS1100 Newbie
      • Jun 2009
      • 1106
      • Battle Ground, Washington
      A normal battery ill take about 18 hours at 10 amps to reach full charge. It is best to load test it after you believe it has a full charge. I personally use a hydrometer to test. May be the charging unit as well.
      1980 XS1100LG Midnight
      1991 Honda CBR1000F Hurricane
      A cold beer and another one!
        What kind of battery charger is it? Check the electrolight level in the battery.
          Definitely check the fluids if it is not a maintenance free type. Otherwise, your battery sounds very suspect. I would agree, have it load tested. Chances are it has a bad cell or two and your discharging as soon as the charger quits charging so it kicks back in to bring the charge back up.
          • latexeses
            • Jun 2008
            • 1491
            • California
            How long after the light comes on does it go back to charging?
            Everything on hold...
            • GARTHXS
              • 1631
              • Seattle
              Problem solved my batteeyr is dead
              91 kwaka kz1000p
              Stock
