oil leak
  • nemesis71
    • 12
    • ohio
    oil leak
    1978 sx 1100 oil leak on very bottom of stator side case.Installed new gasket and check for crackes. No crackes but still dripping oil out of what looks to be a weep hole of some kind. Any help? Thank You
    It's the o-ring around the oil galley plug. Just pull the stator (that gasket does nothing, really) and pull the plug out of the hole at the bottom. Leave the bike on the sidestand, and all you might get is a couple of drips of oil. Replace the o-ring, and put the plug back in. Re-install the stator, and you're done.
    Never try to start the bike with the stator off, since it holds that plug in place. If you do, it will shoot the plug out, along with a nice supply of oil.
    • nemesis71
      • 12
      • ohio
      Great help. Thanks
        Maybe...
        Is it simply dripping oil and not making a mess inside the cover, or is your stator/rotor covered in oil also? If it's making a mess in there, it's more than likely your crank seal. With that cover off, you can grab your rotor and pull up and down on it. If it has any movement at all, then your crank bearings are getting bad and letting the crank wobble a bit... causing the seal to leak.
        If the seal is leaking and the crank DOESN'T move at all, it could simply be a 30+ year old piece of rubber that wore out.
        Good luck and let us know what you find.
        • old_chopper
          • Sep 2010
          • 120
          • Oklahoma
          I have the same leak and took the stator off and cleaned it up inside. Can you give me a clock position where the plug is relative to the crank? There was one plug type dealio with a 1/2" long stem on it but I couldn't pull it out. Maybe a picture of the plug? I don't think mine is the seal as the rotor was clean.
          US Army 1986-1991
          1979 1100 Special (on the road after 16 years!)
          1983 GS300L (wifes ride)
          1985 Super Glide
          2012 Super Glide
            That's the plug. The part that sticks out is pressed in by the alt. cover, and that keeps the plug in place. Grab that stem and pull, but be careful, as it can break off.
              • 8928
              Six o'clock at the oil galley.
                • 7828
                Hey, just pull al the spark plug leads, and turn the engine over with the cover removed! That SHOULD send the plug out. (IF you DO try this, be VERY CAREFUL!)
                • old_chopper
                  • Sep 2010
                  • 120
                  • Oklahoma
                  If I can't pull it loose I will give this a modified try, I'll loosen the cover enough to let it move but still capture the missle when it's launched.
                  US Army 1986-1991
                  1985 Super Glide
                  2012 Super Glide
                  • cywelchjr
                    XS-XJ Super Guru(Deceased)
                    • 4450
                    • Sacramento, CA
                    Not a good idea to just loosen the cover and then crank the engine, as the rotor would rub the stator and can damage it even at that slow rotational speed. Best to take the cover off and put a bucket in position to catch that thing if it comes out too fast.
                      • 8928
                      Sombody said they want photos?
