Toyota's problem?
  • WMarshy
    • Apr 2009
    • 2402
    • Mexico NY
    Toyota's problem?
    The simple explanation.
    '79 XS11 F
    Stock except K&N
    '79 XS11 SF
    Stock, no title.
    '84 Chevy K-10 "Big Blue"
  • TADracer
    • 1417
    • Kenner, Louisiana USA
    Hey, I think I had one of those! But the Janelson Rod fell off of the Knibbley Pin and the whole thing froze up. Left me standing on the side of the road asking myself, why didnt I just buy a bicycle?
    Mike Giroir
    79 XS-1100 Special
    • Poprock
      • Apr 2005
      • 594
      • Oregon Coast
      You know, I think that will hook up to the shaft of an XS11! I gotta talk to Tony about that.
      • XJOK2PLAY
        • 2099
        • Skiatook, Ok.
        Yeah... uhhh huhhh.... what he said....
        2011 Kaw Concours 14 ABS
        • WMarshy
          • Apr 2009
          • 2402
          • Mexico NY
          I think that would require bypassing the drawn reciprocation ding alarm and extending the differential gerdal spring from the grameters over to the hoyrocoptic marzilvanes.
          '79 XS11 F
          Stock except K&N
          '79 XS11 SF
          Stock, no title.
          • kirmit77
            • Mar 2009
            • 464
            • Kingwood, TX
            wow......
            just, wow.........
            Austin Ingalls
            MIDNIGHT FURY
            1979 XS1100 Special [Full Restore Project]
            XJ maxim rear air shocks
            KERKER 4-into-1 exhaust
            Pod Filters
            Money pit.......
            BLACKED OUT
              The flaybar bent and the 'cuda valve stuck.
              Regards,
              Scott
              • Brad
                • 136
                • Regina, SK CANADA
                Understand that it is read from top to bottom right to left, then realize that left is go and right is stop, palce larger mat on left with left handed koter pin between "universal" right hand drive vehicals. Made for the USA in the left hand drive configuration, the computer programer frogot to tell the computer to put the koter pin in right handed, hence lock up on the lip of the mat.
                As we all need to press blame and fault, didn't we shift from neutral to drive to get it moving? Wouldn't common sence tell you to reverser your action? Kinda like when you move you hand towards something hot, you reverse our action and move it away.
                If you went from N to D to inguage the transmition and make it move, how simple do you have to be to not realize that moving out of D back to N will stop ingauging the transmition?
                I think I will sue for 1.5 million, cause I passed the drivers test understanding the basics of how an automible works and the rules of the road. I didn't realize that if there is a problem creating constant force forward in my car that my brakes don't stop, it must be the fault of the people that made the car, not me by dis ingauging the transmision that makes it go forward.
                Some make 'em, most just make payments on 'em!
                1978 XS 1100E
                Vance & Hines Slip on Straight Shot Exhaust
                K & N Air filter
                Home built forward controls
                Vulcan Mustang seat
                A little chopped
                http://s812.photobucket.com/albums/zz42/Brad_099/
                • ScottsXS
                  • Sep 2005
                  • 169
                  • Demotte, IN
                  aaaaaaa..........DUH??????????? i feel dumber from watching that........but it was funny
                  when in doubt...get a bigger hammer
                  '78 XS11e, '79 XS11sf,'81 Mazda RX7, '83 XJ650lj Turbo, '95 Ford F150, '93 Chevy K2500, '04 Honda Pilot,
                  '89 Arctic Cat Wildcat, '89 Arctic Cat El Tigre 530, '81 Arctic Cat Trailcat 340, '79 john deere trailfire 440,
                  '78 Cadillac Seville
                  Don't steal the government hates competition
                  • WMarshy
                    • Apr 2009
                    • 2402
                    • Mexico NY
                    3Phase,
                    Under further review, it was found that the flaybar bent because the cuda valve stuck. We ended up bypassing the drawn reciprocation dingle alarm and extend the differential gerdal spring from the cardinal grameters over to the transcendental hopper dadoscope. Then refabed the pentametric fan to accomidate an extended trem'e pipe. This should handle the increased florecent score motion from XS-sinusoidal depleneration.
                    '79 XS11 F
                    Stock except K&N
                    '79 XS11 SF
                    Stock, no title.
                      • 8643
                      NO dinglehammering your flaybar.....
                        I'm pretty sure thats illegal in at least 39 states! But what two....or one...consenting adult do in private....
                        • gareth
                          • Jul 2007
                          • 259
                          • New York City
                          No one has importuned the mention of how desential the reverberating gasketator is in the machines. Poor dajusment = Peace poor preformance.
                          When dialing in the osscillading diapram, keep an eye on the tator gouge as she throttles.
                          It doesn't get much ease, Sir, than that.
                            Again? It seems like the 'cuda valve always always sticks WFO and those OEM cast pot metal flaybars just can't handle the load, allowing the tator gouges to reverberate; could have used forged flaybars but no!
                            Regards,
                            Scott
                            • Guy_b_g
                              • May 2007
                              • 790
                              • Beverly Hills, Florida
                              Could it be an Engrish problem?
                              Guy
                              '78E
