What condition is your XJ1100 '82-'84?
    • 6753
    Since I have not seen the appropriate poll for the XJs' ...I thought I'd start one... Mine is Non spec and is in Very Good Cond.
    25
    A Spec. Bike in MINT Cond.
    0.00%
    0
    A Spec. Bike in VERY GOOD Cond.
    24.00%
    6
    A Spec. Bike in GOOD Cond.
    16.00%
    4
    A Spec. Bike in LESS THAN GOOD Cond.
    12.00%
    3
    Non-Spec. Bike in MINT Cond.
    12.00%
    3
    Non-Spec. Bike in VERY GOOD Cond.
    20.00%
    5
    Non-Spec: Bike in GOOD Cond.
    8.00%
    2
    Non-Spec. Bike in LESS THAN GOOD Cond.
    4.00%
    1
    MY XJ is a BASKET CASE
    4.00%
    1
    1980 XS650G Special-Two
    1993 Honda ST1100
  • cywelchjr
    XS-XJ Super Guru(Deceased)
    • 4450
    • Sacramento, CA
    That's why I didn't put them in my poll, the 78-9's were covered and I figured the XJ's rated their own poll.
    (that's my story and I'm sticking to it.)
    • kjohnson
      • Aug 2007
      • 202
      • Wetaskiwin, Alberta, Canada
      I voted that mine is non-spec - less than good, only because there wasn't a "good" category. I got it missing most of the air box, it has some wiring issues, the gauges aren't all that good and it really needs paint and polish. Wait, I guess that would put it in the "less than good" category. Hopefully I can get some time to polish and paint it a bit as that is the majority of the issues. If I could figure an alternative for the tach and speedo for cheap, I'd ditch the factory uglies.
      There is a possibility that I am being to harsh on my judgment of her, but I love her none the less.
      K. Johnson
      -1978 XS750SF - brought back from the dead with carb
      triple clean and boots
      -1982 XJ1100J - brought back from the dead by
      replacing motor after throwing #4 rod
      -1985 XJ750XN - shim job, oil change, ride. not bad for
      $500 including new rear tire.
      • barberad
        • 416
        • the 45th state
        I agree with K.Johnson. You should have had a good catagory. I would have rated mine a little higher but still havent gotten around to the 1st gear fix, so it's only a 4-speed
        Current Rides: '82 XJ w/Jardine 4-1's, GIVI flyscreen, '97 Triumph Trophy 1200
        Former Rides: '71 CB350, '78 400 Hawk, '75 CB550/4;
        while in Japan: '86 KLR250, '86 VT250Z, '86 XL600R, '82 CB450(Hawk II), '96 750 Nighthawk, '96 BMW F650
          • 6753
          Yeah I will talk with TC and see if he can amend the poll to include "Good"
          1993 Honda ST1100
            Hey Johnson and Barberad,
            Your VOTES have been adjusted accordingly with the Editted poll results!
            PS, BNE/MadMax, could you explain what you mean by Non-Spec vs. A-Spec,
            As in fully up to specifications or what??
              • 6753
              Well TC I basically copied this language from the other polls. I am assuming Spec. to mean a bike that is stock... as it came from the factory with the exception of normal wear and tear items like tires... So if you have out on pod filters and rejetted the carbs but otherwise your bike s stock...it has been modified thus is Non Spec. BTw Thanks for the help on the poll...
              1993 Honda ST1100
              • SFerinTEXAS
                • Jun 2006
                • 876
                Would an X-! faring count as spec? It does say Yamaha I believe. Other than that and the maybe temporary pod filters mine seems all original. Will be posting photos soon.
                79SF
                XJ11
                78E
                  • 6753
                  If its been on the bike since the beginning i guess it could be spec.
                  1993 Honda ST1100
                  • Kronk
                    • Jul 2010
                    • 165
                    • Grande Cache, AB
                    There is no "My Bike Is An Abomination" category...
                    82 XJ11..... PO was a tool... spray painted with flat black the fenders, tank, and exaust... fenders chipping, and chrome is shining through... tank is fading and running... and exaust is bubbled, and chipped.... also he laid it down at 80km/h... drunk... without a liscence... on gravel
                    There are only two types of bikers...
                    those that have layed it down, and
                    those that have not layed it down...YET!
                    1982 XJ1100J Maxim (F-Bomb)
                    Not going to lie, Brand new at this... thanks for having a bit of patience with dumb questions
